I'm very experienced with tech stuff, but networking is not my forte -- so could use a bit of clarity on securing things.
I have a Ubiquiti USW-Pro-Max-16-PoE that my Dahua cameras will be connected to and a Dahua NVR. I've watched countless videos and read countless blog and forum posts on how to setup networking so that the NVR and cameras are on separate VLANs, the NVR can see the cameras, but the cameras are completely isolated.
I know that you have to do some port magic on the switch to make sure that only certain VLANs can be used on a given port, some might be native, some might be tagged.
What I'm not clear on is if you setup the above properly, if you still have create firewall rules (anywhere), and exactly how they should beconfigured.
Perhaps my confusion partly stems from the fact that much/all of the config could be done on the switch only (not sure) or that some of it should be done (or has to be done) on the router as well.
Thanks in advance for any enlightenment --
