Hi
I wish to secure a house (39ft x 53ft) and an inclined garden around it (about 65ft x 50ft).
No light outside (only moon light).
I need to secure this area with some cameras,motion detectors, ... and i need some advises.
Here the devices i was thinking to use to secure the area:
- nvr (5216-4ks2)
- HDW5231R-Z
- HDBW5231R-Z
- siren (need to get )
- IR barriere (GZGMET photoelectric Transmitter Receiver Passive Ir Beam Infrared Barrier Sensor Gsm wired Alarm System Perimeter Detector-in Sensor & Detector from Security & Protection on Aliexpress.com | Alibaba Group)
- motion detectors (need to get )
I wish to have led light or IR illuminators turn on when motion detector get something in the garden area, and when someone enter via balconies then start to record the events on the nvr.
I don' know what will be the best way to get the best image result during night recording:
- using a PIR Motion sensor lamp LED (10w 20w 30w 50w 70w DC 12V waterproof PIR Motion sensor Induction Sense lamp LED Flood Light Outdoor Lamp-in Floodlights from Lights & Lighting on Aliexpress.com | Alibaba Group) like this one (12v-50w)
- or using IR illuminators ?
I have also balcony that i wish to secure with IR barriere or something better.
I need to know what will be the best choice to install the camera and the lighting and to get the correct hardware.
Is it also possible to advise me the best place to install the cameras to get the area covered.
Thanks.
- nvr (5216-4ks2)
- HDW5231R-Z
- HDBW5231R-Z
Thanks.
