SD5A425GA-HNR detects cat ??
Tinman
1,355
1,785
USA
I have had this happen a few times lately that my cam detects and auto tracks an animal. In this case it is a cat. But a while back it was a possum.
Here is the clip from card:
Here is my settings and firmware details:
This is the clip exported from BI:
Your SD5A425GA-HNR :thumb: video makes my SD4A425DB-HNY :banghead: look like something that came out of a Cracker Jack box.
My HDW5231R-Z 2mp camera puts a green box around our dogs whenever they are in view of the camera in the backyard. The green box goes wherever they do
Yes, we also make a special animal tracking fw for the PTZ5A4M-25X (SD5A425GA-HNR), this camera is very sharp, but bit expensive.
@guykuo have a good video capture the bear :winktongue: audio i think he installs an external voice pickup.
Yes, we also make a special animal tracking fw for the PTZ5A4M-25X (SD5A425GA-HNR)....
Animal tracking firmware? I would love to have that on my PTZ5A4M-25X cameras. I only have the General_SD-Taurus_MultiLang_PN_Stream3-Normal_V3.200.0000018.2.R.240617 which does not track animals.
The bear video was manually aimed, but getting firmware that also does animals would be wonderful.
BTW, the audio in that Bear video was created using sound effects in Final Cut Pro. It is not actual recorded audio from the event.
Actually when you use with smart AI NVR, just turn off the target filter will make the animal tracking working, i just send you the DM for the autotracking fw
Nice clips. I would like to make my tracking continue longer once the subject quits moving. As in the cat capture, my tracking duration was set to 60 seconds, yet this did not work, and it returned to home. So far, I think this is a setting we cannot adjust, once the subject stops, it would be nice for a delay setting.
