I moved it a new place and finally set up my blue iris. Thanks for the forum. I added a dual NIC and also VLAN. I have 2 PTZ now ( 2 more to come)
1. SD 49225T-HN ( firmware v2.800.0000000.6.r) and DS 49225XA-HNR (v2.812.0000012.0.r) both were purchased from Andy.
2. The HN series works fine with blue iris and I can use the PTZ using the Dahua 4 PTZ configuration with blue iris
3. For the HNR, the PTZ works perfectly when i log in via the web but I can't use the PTZ function with Blue Iris. Any suggestions?
PS. the HN did have autotracking which worked amzingly well intermittently. I did upgrade the firmware and now the ptz works fine but nothing on autotracking. Nothing on the HNR. Neither were critical. The HN took a dive and hit the ground during a hurricane and the PTZ would only scroll up and down. I upgraded the firmware and full PTZ is back. Very strange.
Thanks again.
Thanks again.
