Has anyone been able to get the IR toggle button in Blue Iris to work with a Dahua SD49225XA-HNR? I have tried various automatic and manual IR settings in the camera, enabling the CGI service in the camera, and camera configuration and PTZ settings in Blue Iris without success.
I would like to be able to turn off the IR in some areas that are well lit at night and tweaking the automatic sensitivity levels in the camera isn't doing it.
Dahua V5 in the PTZ/Control tab for the camera disables the PTZ so I've used both Dahua V4 and OnVIF (XML) without any luck. I am not against using the Custom HTTP profile commands if that's the only way but would love to see what others have done.
Thanks!
Thanks!
