Hey,
I have an SD49225T-HN that one morning suddenly got stuck rebooting it seems. It won't completely reboot, as it doesn't go through the initial movement of the camera that it does when powering up, but you can hear it click at regular intervals, see the lens zoom in/out, and if I ping it, it seems to respond to pings on 192.168.1.108 for several seconds, then goes to request timed out for several seconds, then goes to host not found, and it repeats that sequence roughly ever 1 minute and 16 seconds (although occasionally it takes longer until it responds again, but typically it follows that pattern).
I tried doing a reset of the camera with the reset button, for various amounts of time, with no change, it always follows that pattern.
So for better or worse, I followed the unbricking instructions (Dahua IPC EASY unbricking / recovery over TFTP) over tftp thinking that if it was a corrupted file, this would be the best way to rewrite the image and hopefully fix it, although I've only had issues with this as well.
The Firmware I used was the latest SD49225T-HN firmware I received from Andy, V2.800.0000000.4.R.191105.
So if I follow those instructions, and here is what I get for an output:
So it looks like it fails to run the dp (partition) command. Do some searching around on that, and see people have had success leaving out the dp command and just doing everything else. So I take out the dp command, and run it and this time get:
Ncat: Version 7.40 ( Ncat - Netcat for the 21st Century )
Ncat: Listening on 192.168.254.254:5002
gBootLogPtr:00b80008.
NAND: 128 MiB
amb_nand_read_oob read page:49152 err
partition file version 2
rootfstype squashfs root /dev/mtdblock8
fail to load bootargsParametersV22.txt
fail to load bootargsParametersV21.txt
fail to init bootargsParametersV2
TEXT_BASE:01000000
Net: Detected MACID:14:a7:8b:87:c9:62
PHY:0x001cc816,addr:0x00
s3l phy RTL8201 init
link down
Using ambarella mac device
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'upgrade_info_7db780a713a4.txt'.Download to address: 0x5000000
Downloading: *
done
Bytes transferred = 201 (c9 hex)
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'romfs-x.squashfs.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 1427704 (15c8f8 hex)
do not find BOOT_IMG_NAME!
Erasing update flag partition.
## Checking Image at 02000000 ...
Legacy image found
Image Name: romfs
Created: 2019-11-05 9:03:08 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1427640 Bytes = 1.4 MiB
Load Address: 01200000
Entry Point: 01600000
Verifying Checksum ... OK
Programing start at: 0x01200000
write : 100%
done
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'kernel.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 1728248 (1a5ef8 hex)
Legacy image found
Image Name: kernel
Created: 2019-11-05 9:03:06 UTC
Image Type: ARM Linux Firmware (uncompressed)
Data Size: 1728184 Bytes = 1.6 MiB
Load Address: 00c80000
Entry Point: 01200000
Programing start at: 0x00c80000
write : 100%
done
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'user-x.squashfs.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 19536120 (12a18f8 hex)
Legacy image found
Image Name: user
Created: 2019-11-05 9:03:29 UTC
Image Type: ARM Linux Standalone Program (uncompressed)
Data Size: 19536056 Bytes = 18.6 MiB
Load Address: 01e00000
Entry Point: 03a80000
Programing start at: 0x01e00000
write : 100%
done
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1Download Filename 'web-x.squashfs.img'.Download to address: 0x2000000
Downloading: *
done
Bytes transferred = 5802232 (5888f8 hex)
Legacy image found
Image Name: web
Created: 2019-11-05 9:03:11 UTC
Data Size: 5802168 Bytes = 5.5 MiB
Load Address: 01600000
Entry Point: 01e00000
Programing start at: 0x01600000
write : 100%
done
## Error: "dp" not defined
cmd Failed run dp!
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
get bootargs info failed
cmdLine console=ttyS0,115200 mem=150M root=/dev/mtdblock8 rootfstype=squashfs init=/linuxrc
NAND: 128 MiB
TEXT_BASE:01000000
link down
Downloading: *
done
Downloading: *
done
Legacy image found
Image Name: romfs
write : 100%
done
Downloading: *
done
Legacy image found
Image Name: kernel
write : 100%
done
Downloading: *
done
Legacy image found
Image Name: user
write : 100%
done
Downloading: *
done
Legacy image found
Image Name: web
write : 100%
done
cmd Failed run dp!
