SD42212T-HN (non S2 version) - looking for firmware
tomas21
Aug 12, 2014
165
23
US
I need to reinstall my firmware but cannot locate the following version that I had on my PTZ..
I have the SD42212T-HN .... i downgraded it to try to fix the motion & video embedded image issue with no success and wanted to upgrade back to the newer version.. I cannot locate the latest bin version below in my NAS.
If anyone has this firmware below or reference to download pls share...
This is the odd image issue where the embedded image doesn't stay in the frame on IE10...
Thats a browser/plugin issue not a firmware issue. Of course if you update FW it may get rid of th plugin and fix it..?
What browser is that?
Try Edge in IE mode
In Edge if you go to More Tools/Internet options/Programs/Manage Addons you might try deleting the plugins for Dahua?
Reactions: shelestoff
I'm using IE 11 in IE mode on Win10. If i run Winxp vm and load up IE it show correctly in the frame... so it is something with Win10 and the IE11 or Edge emulating IE .
I tried disabling and removing from both Edge and IE11 emulated but when adding back issue still exists..
