Looks great. Do you know where to get that? I cannot seem to find any working firmware files.
I sent it to you via PM...use at your own risk.Looks great. Do you know where to get that? I cannot seem to find any working firmware files.
Could you sent me the firmware file as well, i am curios if this is a version that does work on my old camera. Thx.I sent it to you via PM...use at your own risk.
Maybe errrr will reply what he found out.Could you sent me the firmware file as well, i am curios if this is a version that does work on my old camera. Thx.
Alright, could you tell me already what the file size of that firmware (****.bin) file is?Maybe errrr will reply what he found out.
I think there may be confusion about the hardware version. Tinman’s older version is 2018 whereas RyanMM and I have the older still 2015 hardware. We still need the 2.4xxx 2015-06-07 firmware.
So cameras made before 2017-2 will have a smaller eeprom (16MB) and can not load any firmware file that is larger then 16MB.The reason is simply a different hardware revision. Dahua has changed the flash room size for cam's build after 01.17. the older ones have only 16mb the new one 128mb.
They had also a different feature set. The newer one is capable of smart codec and easy4ip / P2P.
And both have a different factory firmware.
ftp:/ftp.asm.cz/Dahua/kamerove_systemy/_Firmware/05SD/PTZ%20firmware%20%20release%20record%2005.07.2017.xlsx
To make a summarization of the confusion that is created by Dahau to use the same type number DH-SD22204T-GN for units that have different hardware revision, in this case the size of eeproms to store the firmware.
As mention by @Dave Lonsdale and @TVT73
I also have a camera with the smaller 16MB eeprom which has production date 2016-11:
It only accepts firmware files which are around 13MB in file size: ( check also the filename part "Zi-Themis").
The Cameras which do have the 128MB eeprom can load larger firmware files: (check also the filename part "Mao-Themis").
Thank you all for the input for this clarification.
Dave Lonsdale, RyanMM, Check your PM's.
DoneI'm assuming you sent those guys the older version through PM? Could I be so forthcoming to ask for a copy? Thanks![]()
Will send you a PM with the specific firmware because it is not available on the internet.I might figured out the problem that I cannot connect to Imou or DMSS app on my phone. My camera does not have the P2P option in the Web approach. In your screenshot there is a firmware version with P2P in it's name: "DH_SD-Zi-Themis_Eng_P_Stream3_P2P_IVS_V2.400.0001.0.T.20170209.bin". Where can I find this version?
2015-06-07 archivo adjunto. En realidad, después de estar satisfecho al principio con este firmware, ahora descubrí que todavía tiene algunos de los problemas que pensé que se introdujeron cuando actualicé al firmware 2016-05-17, aunque por el lado bueno, la cámara no No cuelgues. En consecuencia, me gustaría probar el firmware DH_SD-Zi-Themis_Eng_P_Stream3_P2P_IVS_V2.400.0001.0.T.20170209. Cualquier posibilidad, por favor Errrr o IPCamer, alguno de ustedes se tomaría un momento para publicarlo o enviarlo. Gracias.
[/CITA]
Excelente David, muchas gracias!!!
¡¡¡Ya lo estoy probando!!!
