Ri22o Known around here Jul 30, 2020 1,919 3,918 Indiana Mar 26, 2023 #1 I am starting to put SD cards in my cameras, but not sure how to actually set up for it to record Main Stream on motion/alert. Is this a combination of settings in BI and GUI?
wittaj IPCT Contributor Apr 28, 2019 31,022 59,482 USA Mar 26, 2023 #2 SD card setting is all in the camera - BI does not interact with SD card. If you are using IVS simply check the record box and it will record mainstream whenever the IVS is triggered. Reactions: JDreaming
wittaj IPCT Contributor Apr 28, 2019 31,022 59,482 USA Mar 26, 2023 #4 Then check the record box for MD or SMD, whichever one you setup.
