W winskate n3wb Nov 4, 2017 13 22 Sep 26, 2018 #1 Does the SD 59225u-HNI support IVS? I'm not seeing it in settings menu. I just upgraded the firmware that Andy sent me. Using Smart pss for config.
looney2ns IPCT Contributor Sep 25, 2016 16,321 24,225 Evansville, In. USA Sep 26, 2018 #2 Yes it does, be sure you have not turned on Smart Codec, doing so disables IVS. Reactions: weigle2
W winskate n3wb Nov 4, 2017 13 22 Sep 27, 2018 #3 ok, I found it. In Smart PSS a tab in the events menu called "IVS analysis." Reactions: Cameraguy
