I was going to put this in my other thread but its a bit off topic so I am starting a different one in case someone has a similar question.
The Dahua cameras come set with a static IP of 192.168.1.108. My network is 192.168.255.xxx. Currently, I have to change my local LAN settings on my PC and connect directly to the camera in order to change the IP. Doing a simple search with the scanner program will yield no results due to the camera being outside my network range. Its a pain setting them up this way especially when I have 40+ more to do. Plugging them right into the POE switch would make setup a breeze. Otherwise I have to configure my local PC, find a 12v power source and plug, and manually change the camera info that way. Is there an easier way? Can I scan for a MAC ID if its off network? Any suggestions?
Thanks,
Thanks,
