I have a Samsung SNO-6011R I use in Blue Iris. I can see the video stream fine. Couple issues i have. Currently i use the generic stream
Opening 192.168.1.60 port 80...
HTTP Get / request...
OK
ONVIF GetSystemDateAndTime
2018-07-09T15:10:50.000Z
Requesting device information...
Manufacturer: Samsung Techwin
Model: SNO-6011R
FirmwareVersion: 4.00_180504
GetCapabilities...
Querying services
Has Search services: /onvif/search_service
Has Imaging services: /onvif/imaging_service
Has media services: /onvif/media_service
Has RTP_RTSP_TCP, requesting profiles
first profile is 0119b80a-01c3-4398-911f-46df60782fbb
first source is b1dcc2e3-c45d-4464-b5d7-874e7b4d2a44
requesting URI for profile 0119b80a-01c3-4398-911f-46df60782fbb
RTSP URI: /onvif/profile1/media.smp
Has Event services: /onvif/event_service
Has WSPullPointSupport
RelayOutputs: 0
InputConnectors: 1
Has Device IO services: /onvif/deviceio_service
AudioOutputs: 0
Done
I have a Dakota Alert sensor connected to the input of the camera. The DA is working but i cannot get the camera to trip when sensor trips. I ran the ONVIF Device Manager but the camera does not show up, the other FLIR cameras all show up.
I am wondering if the video path will make a difference? Or if the camera is bad? It should be ONVIF compliant.
Other thing i have is i log into the camera directly and it says the FPS is set to 30 compression rate 10 & max bitrate of 2560. When i look at the Camera Status on BI it shows 5 while the others show 15.
The other camera that shows .89 is also a Samsung. What am i doing wrong?
My CPU usage is really high, should i lower the fps on the rest too? will that help?
Lots of questions in 1 post. Any help is always greatly appreciated.
OK
Model: SNO-6011R
GetCapabilities...
Querying services
RelayOutputs: 0
InputConnectors: 1
AudioOutputs: 0
Done
