setup description:
SAFIRE SF-HTVR8216A-HEVC + 10 ANALOG cameras 5Mpx
LTE connection (countryside area not served by cabled providers, public ip released by service provider to allow remote access) via a Tp-Link ArcherMR200 router/modem
LTE Router ip x.x.x.1
NVR withstatic ip x.x.x.104
virtual server for x.x.x.104 :
DDNS enabled and workin with NO-IP.net
Stream encryption disable
This said I'm able to remotely access both via seller Cloud service and straight via IP.
I can watch video streams using both Android and Windows Safire Control Center; on windows using IE web browser the web access is fully working and I can watch video streams too. On Mac OSX the iVMS-4200 is working fine (both via Cloud and via IP), while the browser access on the mac is ok only for configuration since the video-plugin seems not to be recognized any more (but I don't care).
Now, I'm interested in accessing and watching the straight video streams using VLC, for example, or with a third party security app. (for example a continuos play of the ZERO-channel).
Looking here and there I've found these suggestions:
Tried both with and without the / at the end of the path. Setting the sub stream to H264 sul but nothing.
Maybe I'm missing some step.
- HTTP ext 36274>int 80 TCP
- RTSP ext 56187>int 554 TCP
- HTTPS ext 36286>int 443 TCP
- SERVER ext 40060>int 8000 TCP
- EASYCOMMAND ext 48669>int 9010 TCP
- EASYCOMMANDDATA ext 58725>int 9020 TCP
Code:
rtsp:/admin:[email protected]:56187/Streaming/Channels/101/
(main stream H265)
rtsp:/admin:[email protected]:56187/Streaming/Channels/102/
(sub stream H264)
