Grr this 2CD2342 is running me a merry game
Ok so following on from powering the thing, i finally gained access to the UI and reset the cam back to factory settings
Using SADP i can see the ip address and default gateway will be wrong for the install location
i can change the ip address and ipv4 gateway on the right to what i need but if i use 12345 as a password and hit save i get an error saying
failed to modify the settings ID:001 ??
what am i doing wrong, is the default password not 12345 ??
and reading the manual sometimes helps, however i would like to point out i am a Male, therefore its not my fault
