Hi all,
I have an AvertX 16 Channel with 8 Cameras from Costco arriving this weekend. My question to you all is, how did you manage to run all your cable to the NVR? It’s going to be located in my office and I was thinking of installing a 12-Port faceplate then running a short length cable to the NVR from the faceplate for each. If I did this, would I impair the system at all from adding in a connection? Camera > Face Plate > NVR.
I’ve read a couple threads on using a PoE switch then only needing to run a single cable but I wasn’t originally planning on that. Open to all recommendations.
Thanks!
Thanks!
