I can't decide which route to take when running wires to my NVR.
Option 1 would be to just to connect wires straight through the wall and into NVR. Like so:
Option 2 would be to use keystones and connect NVR to each keystone. My only concern is data transfer speed. Would this affect the data transfer speed at all, as compared to option 1? Is there a noticeable difference?
Most professional installations I've seen use option 2. IMO, option 1 looks a bit cleaner.
Thanks all for you input!
