Hi, when we had our house renovated I had CAT6 cable run to three exterior points around the house approximately where I planned to install security cams in future. The cables are coming from the inside of the house in an area under the stairs where they all meet and a hole was drilled at each of the three locations to get the cable outside. I am now about to put the cams up and will need to run the cable from where it is currently to the exact point my POE cams will be which is likely to be no more than a 4-5 metre run across the wall in a straight line. What kind of protection do I need to use on the cables? Most things I've read suggest using a special outdoor use cable but the cable I've had run is standard CAT6.
Any help would be appreciated.
