While trying to figure out how to get POE lines up into my attic from the basement of my two story house through interior walls, the straightest and easiest shot, I thought, would be through the return air duct work to the ceiling height return air vent in an upstairs bedroom, then just one hole to drill above that to the attic and foam seal up the holes aftereward. (I've done this before on the 1st floor to run a sat cable to the master bedroom).
I removing the bedroom vent screen and looked down the return air duct wall in the bedroom...to my surprise it appears to drop the two floors down but then it just dead ends dry-walled off at the bottom and no air passages through to the HVAC can be seen?!
It does not appear to turn or go into any return air passage in the basement at all. (The dark area along the two 2x4s is just more drywall)
Does that make any sense?
