Windows 10
Blue Iris v4.5.0.2 (running as service)
I’ve enabled run as a service and have run the “remote access wizard”. On rebooting the computer, Blue Iris seems to loose the previous bind address and instead runs the web service on the loopback (127.0.0.1) instead of the static IP I’ve assigned the computer.
I can fix this by re-running the remote access wizard from the Web Access preferences, however I need to do this on every single reboot.
Is this a known bug? Is there a way for me to enter the LAN IP instead of relying on the wizard?
