Run as a Service, Console will not open
jdguest
Apr 24, 2020
3
Hickory Hills, IL
I am running 5.2.9.12 x64 as a service on Win10 Pro and the console will not open. If I stop the service I can open the console. Any suggestions?
do not upgrade !!!!!!!!!!!!!
Make sure the service is running with an Admin account.
Use 5.2.6.5 the last known stable update.
If you run services.msc, then find the BI service make sure that it is running using the same account as that which you’d normally use to logon to the Pc.
SouthernYankee, I was not able to find 5.2.6.5, so regressed to 5.2.7.9 which has the same error. Prior update listed is 5.2.7.8 or 5.2.6.1. Do you have a link for 5.2.6.5?
