Rubber Seal ? Wire pass thru ?
tech101
1,542
2,289
SF BayArea, USA
Hi Junction box comes with this Rubber Ring With a slit in the middle where you can make the cable go thru and then plug that rubber ring in to the hole to seal it properly. Do you know where Can I buy those and specifically for the hole in behind the PFA120 ? It does not have to have the slit in the middle or wire pass thru just something to seal it up.. Wonder why the hole is there to begin with since I connect the conduit anyways to feed the wire up to the junction box
Thank you so much I will try those options.
