I have a Hikvision IP camera which I am trying to stream using RTSP by coming through Pfsense 2.7 using my internet domain name.
I can RTSP stream the IP camera just fine when it is accessed from my internal (10.0.0.237) network. I can also access it just fine from the internet to view the internal web viewer. I cannot seem to access it from the internet when trying to RTSP stream.
I am using Pfsense 2.7 on my Router and have port forwarded the HTTP port (93) to the appropriate internal address and this allows access to the web viewer.
I have also port forwarded the RTSP port (567) to the same internal address but this does not seem to allow the RTSP through as I have tried three different iOS streaming apps and none connect.
Since it streams and views fine on my internal network I know the IP camera and ports number setup are working fine. Since I can view the internal web viewer remotely I know the Pfsense port forwarding and firewall process are working fine (at least for the HTTP port).
This leads me to think that I am missing something in Pfsense in regards to what I actually need to port forward. Apparently I either have it setup incorrectly in Pfsense or I need to allow something else through Pfsense to view the RTSP stream.
I have the NAT rule setup in Pfsense on the WAN interface as a TCP/UDP pointing to the camera's internal address and RTSP port number just like I have on the HTTP port rule.
10.0.0.237:93 Views just fine
rtsp:/10.0.0.237:567/Streaming/channels/101 Streams just fine
xxxxxx.ddns.net:93 Views just fine (my external domain name port forwarded in Pfsense)
rtsp:/xxxxxx.ddns.net:567/Streaming/channels/101 never connects (my external domain name port forwarded in Pfsense)
I can ping xxxxxx.ddns.net fine so I know my router is seeing the RTSP request just fine.
Can anyone tell me if I need to open more ports in Pfsense and what they are or how to configure the RTSP port in Pfsense to allow external streaming?
