rtsp to m3u for Samsung smart iptv
Jagradang
Aug 10, 2017
179
36
I'm looking for a way to get my IP Cameras to show up on my TV. I have installed Smart IPTV and was hoping to try and use the rtsp link for each camera to stream to the tv but can't seem to get it working. So the question it
- Has anybody done this and got it working?
- Is it possible?
I have a Dahua NVR and Ip cameras setup.
Any help appreciated!
Hi Jagradang,
Have you thought about using a HDMI option from the NVR? Or using a browser on your TV to access the NVR web interface?
Thanks for the reply, browser won't work because of dahua plug in installation. Nvr is in a different room so the only way would be to get a hdmi over ethernet connection box. I Was hoping to avoid that if possible but it may be the only way if nothing else works. I have installed smart iptv on the tv and it does work either rtsp streams but just won't load my cctv stream. Was hoping someone on here had used it or atleast knew how it worked but doesn't seem that way.
Sent from my SM-G935F using Tapatalk
