Hello you knowledgeable folk, I wonder if any of you have experience with the following.
I have a DS-2DE4425IW-DE that is solely being used as a live web cam, unfortunately it operates at a reduced frame rate and frame size due to a poor internet connection.
However I do have a static internet IP, so currently I stream using the RTSP protocol.
To improve the image, I am looking at getting Starlink with it's high available bandwidth, the problem here, with out a lot of messing about means I cannot use RTSP as Starlink, from what I understand uses CGNAT.
So what it might have been easier to say from the start, does anyone know of some firmware for the DS-2DE4425IW-DE that has the RTMP protocol installed.
Many Thanks in advance
Aid
Aid
