Hi all,
New to this forum (and Blue Iris) but I'm getting the hang of it slowly... here's my scenario:
I have a 4k (Annke C800 turret) camera that due to the area I'm looking to cover I'd like to rotate 90 degrees in BI. When I do, I lose about 5fps from the feed, which wouldn't be so bad if it didn't then start delaying the whole feed and having it get minutes behind the rest of the cameras over time.
Originally I used a Wyze v2 camera to cover the same area and rotating that image did not result in any frame drops. Am I correct in assuming this is a re-encoding effect, as since I'm rotating the image BI is re-encoding it? Or, is there something else I'm missing?
To be fair it's only a small irritation as now that I have the substream working right the multi-cam preview stays in-sync... it's only when I solo the cam that the drops occur.
Any ideas would be appreciated - thanks in advance!
