Rooting around in the Longse / Cantonk S500
alastairstevenson
Staff member
Oct 28, 2014
16,362
7,118
Scotland
Well, I've been away from this forum for a while due to a need to service a higher-level interrupt. But that's pretty well OK now, so I have a bit of time to play again.
I thought I'd take a break from unpicking Hikvision's ongoing efforts to trip up their customers and have a root around inside the Longse / Cantonk offerings.
Being an engineer by inclination and training I like to know 'how things work'.
This is probably just for the techies amongst us, and might be only of academic interest with limited practical value.
After all, unlike the Hikvision firmware, the Herospeed firmware has no encryption to break, no obfuscation to figure out, no tripwires to defeat, no tamper or integrity protection to sidestep.
It's not the world's most sophisticated IP camera firmware, though. It would be really good if Herospeed would add some advanced analytics beyond simple motion detection.
So this is the 'Longse S500' camera, as brought to our attention by @klasipka and has deservedly received quite a lot of attention for image quality and low-light performance.
Let's have a look at what's running on the pretty good H3516a / IMX178 hardware combo.
Quite a current version of the Linux kernel, and the very capable 1.2GHz 32-bit ARMv7 CPU.
Not overly generous with the RAM though at 64MB.
Code:
alastair@PC-I5 ~ $ telnet 192.168.1.168
Trying 192.168.1.168...
Connected to 192.168.1.168.
Escape character is '^]'.
(none) login: root
Password:
Welcome to HiLinux.
None of nfsroot found in cmdline.
~ # uname -a
Linux (none) 3.4.35 #4 Thu Jan 22 15:23:55 CST 2015 armv7l GNU/Linux
~ # pwd
/root
~ # cat /proc/cpuinfo
Processor       : ARMv7 Processor rev 5 (v7l)
BogoMIPS        : 1196.85
Features        : swp half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xc07
CPU revision    : 5
Hardware        : hi3516a
Revision        : 0000
Serial          : 0000000000000000
~ # free
             total         used         free       shared      buffers
Mem:         59552        53440         6112            0            0
-/+ buffers:              53440         6112
Swap:            0            0            0
The camera is currently providing 2 RTSP streams, and the CPU is almost idling.
Code:
Mem: 58076K used, 1476K free, 0K shrd, 0K buff, 28416K cached
CPU0: 10.5% usr  1.9% sys  0.0% nic 87.4% idle  0.0% io  0.0% irq  0.0% sirq
Load average: 4.49 4.45 4.66 1/113 1291
  PID  PPID USER     STAT   VSZ %VSZ CPU %CPU COMMAND
  849     1 root     S     163m279.8   0 10.8 /usr/AVServer
 1116     1 root     S     229m392.5   0  0.4 /boaServer/boa
  854     1 root     S     128m219.9   0  0.4 /usr/SystemServer
 1114     1 root     S    88408147.8   0  0.4 /usr/freep2p_server
 1118     1 root     S    36088 60.3   0  0.1 /usr/DeviceSearch
 1291  1287 root     R     1772  2.9   0  0.1 top
    3     2 root     SW       0  0.0   0  0.1 [ksoftirqd/0]
 1287   844 root     S     1784  2.9   0  0.0 -sh
  844     1 root     S     1772  2.9   0  0.0 telnetd
  841     1 root     S     1768  2.9   0  0.0 /bin/login
    1     0 root     S     1764  2.9   0  0.0 init
 1123     1 root     S     1268  2.1   0  0.0 /usr/WatchDog
  593     1 root     S <   1068  1.7   0  0.0 udevd --daemon
  670   593 root     S <   1068  1.7   0  0.0 udevd --daemon
  661   593 root     S <   1068  1.7   0  0.0 udevd --daemon
  845     1 root     S      848  1.4   0  0.0 /usr/Main
 1080     1 root     S      840  1.4   0  0.0 /usr/HWatchDog
  579     2 root     SWN      0  0.0   0  0.0 [jffs2_gcd_mtd2]
  249     2 root     SW       0  0.0   0  0.0 [kworker/0:1]
  161     2 root     DW       0  0.0   0  0.0 [kusbotg]
What about storage?
Nothing unusual in the size or the layout.
Code:
~ # df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root                12.0M      9.3M      2.7M  78% /
tmpfs                    29.1M      4.0K     29.1M   0% /dev
nome                      4.0M      4.0M     20.0K 100% /boaServer
~ # cat /proc/mtd
dev:    size   erasesize  name
mtd0: 00100000 00010000 "boot"
mtd1: 00300000 00010000 "kernel"
mtd2: 00c00000 00010000 "rootfs"
~ # ls -al /
total 2
drwxr-xr-x   25 root     root             0 Jan  1  1970 .
drwxr-xr-x   25 root     root             0 Jan  1  1970 ..
drwxrwxr-x    2 1000     1000             0 Feb  5  2015 bin
drwxrwxrwt    2 root     root            60 Jul  1 20:59 boaServer
drwxrwxr-x    2 1000     1000             0 Feb  5  2015 boot
drwxrwxrwt    6 root     root          3320 Jan  1  1970 dev
drwxr-xr-x    2 1000     1000             0 Feb  5  2015 disk
drwxrwxr-x    5 1000     1000             0 Apr 16 16:25 etc
drwxrwxr-x    3 1000     1000             0 Feb  5  2015 home
lrwxrwxrwx    1 1000     1000             9 Feb  5  2015 init -> sbin/init
drwxr-xr-x    3 1000     1000             0 Apr 16 16:25 ko
drwxrwxr-x    2 1000     1000             0 Apr 16 16:25 lib
lrwxrwxrwx    1 1000     1000            11 Feb  5  2015 linuxrc -> bin/busybox
drwxrwxr-x    2 1000     1000             0 Feb  5  2015 lost+found
-rwxrwxr-x    1 1000     1000           431 Feb  5  2015 mknod_console
drwxrwxr-x    2 1000     1000             0 Feb  5  2015 mnt
drwxrwxr-x    2 1000     1000             0 Feb  5  2015 nfsroot
drwxrwxr-x    2 1000     1000             0 Feb  5  2015 opt
drwxr-xr-x    2 1000     1000             0 Jan  1  1970 param
dr-xr-xr-x   65 root     root             0 Jan  1  1970 proc
drwxrwxr-x    2 1000     1000             0 Jun 29 19:59 root
drwxrwxr-x    2 1000     1000             0 Feb  5  2015 sbin
drwxrwxr-x    2 1000     1000             0 Feb  5  2015 share
dr-xr-xr-x   12 root     root             0 Jan  1  1970 sys
drwxrwxr-x    2 1000     1000             0 Jan  1  1970 tmp
drwxrwxr-x    6 1000     1000             0 Jun 24 20:41 usr
drwxrwxr-x    3 1000     1000             0 Feb  5  2015 var
When analysing embedded Linux, exploring the internals, trying out changes, it can be really useful to have external storage available, avoiding the need to shuffle files back and forward with tftp etc, so an NFS mount is almost mandatory.
As there is no 'NetHDD' facility in the web GUI, this can be done via terminal.
It's interesting to note that, as Hikvision also do to some extent, there are hooks left in place in the system initiallisation to support an NFS based rootfs, an essential part of the development and analysis environment.
The NFS mount makes it easy to pull out the flash contents, and anything else, to see how things are organised. And to change things experimentally.
Code:
~ # ls -al /mnt
total 0
drwxrwxr-x    2 1000     1000             0 Feb  5  2015 .
~ # mount -t nfs -o nolock 192.168.1.21:/home/alastair/tftp_root /mnt
~ # ls -al /mnt
total 16
drwxrwxrwx    5 1000     1000          4096 Jul  1 20:38 .
drwxr-xr-x    2 1000     1000          4096 Jul  1 20:37 imx178
drwxr-xr-x    2 1000     1000          4096 Jul  1 13:04 imx322
drwxr-xr-x    2 1000     1000          4096 Jun 29 18:33 tmp
~ # cd /mnt/imx178
/mnt/imx178 # dd if=/dev/mtd0 of=mtd0
2048+0 records in
2048+0 records out
1048576 bytes (1.0MB) copied, 0.866129 seconds, 1.2MB/s
/mnt/imx178 # dd if=/dev/mtd1 of=mtd1
6144+0 records in
6144+0 records out
3145728 bytes (3.0MB) copied, 1.096895 seconds, 2.7MB/s
/mnt/imx178 # dd if=/dev/mtd2 of=mtd2
24576+0 records in
24576+0 records out
12582912 bytes (12.0MB) copied, 3.986917 seconds, 3.0MB/s
/mnt/imx178 # ls -al
total 16392
drwxr-xr-x    2 1000     1000          4096 Jul  1 20:46 .
drwxrwxrwx    5 1000     1000          4096 Jul  1 20:38 ..
-rw-r--r--    1 root     root       1048576 Jul  1 20:46 mtd0
-rw-r--r--    1 root     root       3145728 Jul  1 20:46 mtd1
-rw-r--r--    1 root     root      12582912 Jul  1 20:46 mtd2
Here is an interesting folder - what's in it?
It's the system configuration, in a binary file, and the 'factory defaults' settings.
Parts of the layout are self-explanatory from the contents, and much of the organisation can be determinined empirically by adjusting web GUI settings and observing the result.
Code:
/mnt/imx178 # ls -al /param
total 85
drwxr-xr-x    2 1000     1000             0 Jan  1  1970 .
-rwxrwxrwx    1 root     root            41 Apr 16 16:25 Ver.ini
-rw-r--r--    1 root     root           528 Jul  1 21:47 cloud_storage.cfg
-rw-r--r--    1 root     root         57604 Jul  1 21:11 logfile.log
-rw-r--r--    1 root     root            45 Jul  1 21:11 net.conf
-rw-------    1 root     root         10284 Jul  1 20:59 onvif.cfg
-rw-r--r--    1 root     root          8000 Jul  1 21:11 sysenv.cfg
-rw-r--r--    1 root     root          8000 Jan  1  1970 sysenvcopy.cfg
/mnt/imx178 # cat /param/Ver.ini
[VERSION]
sofvar=3516A_IMX178_X_5.1.51.3
/mnt/imx178 # cp /param/* .
total 16492
drwxr-xr-x    2 1000     1000          4096 Jul  1 20:47 .
-rwxr-xr-x    1 root     root            41 Jul  1 20:47 Ver.ini
-rw-r--r--    1 root     root           528 Jul  1 20:47 cloud_storage.cfg
-rw-r--r--    1 root     root         57604 Jul  1 20:47 logfile.log
-rw-r--r--    1 root     root            45 Jul  1 20:47 net.conf
-rw-------    1 root     root         10284 Jul  1 20:47 onvif.cfg
-rw-r--r--    1 root     root          8000 Jul  1 20:47 sysenv.cfg
-rw-r--r--    1 root     root          8000 Jul  1 20:47 sysenvcopy.cfg
/mnt/imx178 #
That's probably enough for now. Well done if you managed to read this far ...
More later.
Thanks for sharing. BTW did you upgrade to latest firmware with new UI?
No, I didn't upgrade the firmware, I was just about to go see if you had posted a link to it, I did see that you'd upgraded though.
*edit* Got the new FW that you posted.
I see they have changed the root password. Maybe I'll figure that out before I find out if there are any integrity checks.
The 'Look and Feel' looks vaguely familiar lol!
And interesting that the Hikvision protocol is supported - I wonder if Hikvision smart events are coming - that would be good.
*edit 2*
I've not upgraded with it yet - thought I'd take a look at it first.
It looks like a major re-write. Certainly differently structured.
Reactions: klasipca
Any possibility of being able to tinker and change the max exposure time used in auto mode to a faster exposure time? Some cams like Axis have limited adjustments in the main GUI but have other capabilities tucked away elsewhere if you know where to look.
fwiw, after updating the firmware on my S500's, they show up in Hikvision's SADP.
I wonder if being more hik-like will make them more or less 'hackable'...
I don't think it's clear if auto mode has a configured max exposure time. I'd guess that the greyed out value in the web GUI when on auto is not meaningful.
Looking at what changes in the sysenv.cfg file when AE settings are changed, it looks to me that byte 0x52C is the 0/1 on/off setting, and the bit position in byte 0x52B is the shutter speed value index when AE is off.
To look further, I think we'd need to decompile the program that interprets the settings and commands the sensor.
For info - attached is a set of sysenv.cfg files for various values of the shutter speed.
View attachment sysenv_various.zip
Thx. I'm on vacation now with just a phone but I get what you're saying. Will look closer when I can lay things out better side by side. I suppose it's possible that they don't use a hard value for the max and just let things get adjusted constantly and float. That'd make it hard for an end user to tweak a few bits and produce a miracle.
An interesting curiosity on the Herospeed firmware are some read-only debugging interfaces.
Code:
alastair@PC-I5 ~ $ telnet 192.168.1.168 401
[Trace]: Motion_Alarm_Func 745
[Trace]: motion detect alarm .........
telnet> close
Connection closed.
alastair@PC-I5 ~ $
Code:
alastair@PC-I5 ~ $ telnet 192.168.1.168 402
Auto_Loop 3886: getaddrinfo start
Auto_Loop 3899: getaddrinfo end
telnet> close
Connection closed.
alastair@PC-I5 ~ $
Code:
alastair@PC-I5 ~ $ telnet 192.168.1.168 403
[Trace]: AVStreamGetAVDataThread 372: gTransFormStatusFunc[2](1) == 0
[Trace]: libCloudStorageGetBindDeviceStatus 122
[Trace]: AVStreamGetAVDataThread 372: gTransFormStatusFunc[2](0) == 0
[Trace]: AVStreamGetAVDataThread 372: gTransFormStatusFunc[4](1) == 0
[Trace]: AVStreamGetAVDataThread 372: gTransFormStatusFunc[4](0) == 0
telnet> close
Connection closed.
alastair@PC-I5 ~ $
Code:
alastair@PC-I5 ~ $ telnet 192.168.1.168 404
[Trace]: Common_GetDhcpStatue 2010: dhcpStatue = 0
[Trace]: Common_GetGateway 1913: ret = 0, gateway: 192.168.1.1
DEBUG DD_InitNetworkInfo-931: pInfo->ucDhcpEnable = 0
DEBUG DD_InitNetworkInfo-933: pInfo->ucIpAddr = 192.168.1.168
DEBUG DD_InitNetworkInfo-934: pInfo->ucNetmaskAddr = 255.255.255.0
DEBUG DD_InitNetworkInfo-935: pInfo->ucGatewayAddr = 192.168.1.1
DEBUG DD_InitNetworkInfo-936: pInfo->ucDnsAddr1 = 192.168.1.1
DEBUG DD_InitNetworkInfo-938: pInfo->ucMacAddr = 00:00:1B:06:B2:F3
telnet> close
Connection closed.
alastair@PC-I5 ~ $
By any chance do you have Huisun camera to mess around?
