Before I do this I want to make sure I'm doing it right, and don't end up having to purchase a new license.
After running smoothly for quite a long time, my installation of Blue Iris is suddenly having issues... The "service" appears to be running smoothly in the background, posting images and clips of alert events, but the desktop interface does not load completely. It gets as far as showing the matrix of camera views, but interaction with those cameras is impossible, and I cannot access clips through the desktop interface.
I'm guessing that the best course is to reinstall BlueIris and see if that fixes the issue. What I don't want, however is to lose all the settings I have set up (yes, I failed to back those up, I think). Also, if I'm reinstalling onto the same computer, will I need to "deactivate" BlueIris and then "reactivate" after the reinstallation?
So, any quick tips for the best way to reinstall BlueIris?
I'm currently running version 4.3.9.4 x64.
