With a Ring Doorbell Pro (wired for direct connection with one doorbell with less than 25' circuit), I'm looking at an Elk transformer that will plug into an outlet inside the house. Which model would you suggest and why? 24VAC 40VA VS 16.5VAC 45VA?
The Ring Video Doorbell Pro 2 is, requires a doorbell transformer rated at 16-24 VAC 50/60HZ, 30-40VA max.
What happens when Ring gets 45VA when they state that 40VA is the max?
Elk TRG2440 24VAC, 40 VA AC Transformer with PTC Fuse
Amazon.com
Elk TRG1640
16.5V 45VA
Anixter CS208443
Thanks,
R
Amazon.com
Elk TRG1640
16.5V 45VA
Anixter CS208443
Thanks,
R
