Review- OEM IPC-T2831T-ZS 4k varifocal starlight turret & PFB203W Wall Bracket.
looney2ns
16,327
24,232
Evansville, In. USA
OEM IPC-T2831T-ZS 4k from EMPIRETECANDY
8MP WDR Turret Varifocal Network Camera
Review unit courtesy of Andy (@EMPIRETECANDY) in exchange for a fair and honest review.
Purchase IPC-T2831T-ZS from the IPCT Store
Andy's ipcamtalk vendor forum: link
Andy's AliExpress store: link
Andy's Amazon store: link
Price Approximately US $160.00 shipped.
Purchase from Amazon here: TBD
Andy's Aliexpress store here: Link
Wall Bracket here approx $17.00: Link
(prices and links valid 3/26/20)
8MP, 1/2.7" CMOS image sensor, low illuminance, high image definition
Outputs max. 8MP (3840 × 2160) @15 fps, and supports 2688×1520 @25/30 fps
H.265 codec, high compression rate, ultra-low bit rate
Built-in IR LED, max IR distance: 40 m
ROI, SMART H.264/H.265, flexible coding, applicable to various bandwidth and storage environments
Rotation mode, WDR, 3D DNR, HLC, BLC, digital watermarking, applicable to various monitoring scenes
Intelligent detection: Intrusion, tripwire
Abnormality detection: Motion detection, video tampering, no SD card, SD card full, SD card error, network disconnection, IP conflict, illegal ac cess, voltage detection
Supports max. 256 GB Micro SD card
12V DC/POE power support
IP67 protection
Camera
Image Sensor1/2.7” 8Megapixel progressive CMOS
Effective Pixels3840 (H) × 2160 (V)
ROM128 MB
RAM256 MB
Scanning SystemProgressive
Electronic Shutter SpeedAuto/Manual 1/3 s–1/100,000 s
Min. Illumination0.008 [email protected]
IR Distance40 m (131.23 ft)
IR On/Off ControlAuto/Manual
IR LEDs Number2
Pan/Tilt/Rotation RangePan: 0°–360°
Tilt: 0°–78°
Rotation: 0°–360°
Lens
Lens TypeMotorized vari-focal
Mount Typeφ14
Focal Length2.7 mm–13.5 mm
Max. ApertureF1.5
Field of ViewPan: 113°–31°
Tilt: 58°–17°
Diagonal: 138°–36°
Iris TypeFixed
Close Focus Distance0.8 m–0.8 m (2.62 ft–2.62 ft)
DORI DistanceLensDetectObserveRecognizeIdentify
W85.3 m
(279.9 ft)
34.1 m
(111.9 ft)
17 m
(55.8 ft)
8.5 m
(27.9 ft)
T280 m
(918.6 ft)
112 m
(367.5 ft)
56 m
(183.7 ft)
28 m
(91.9 ft)
Smart Event
General IVS AnalyticsTripwire; intrusion
Video
Video CompressionH.265; H.264; H.264B; MJPEG
Smart CodecYes
Video Frame RateMain stream:
3840 × 2160 (1 fps–15 fps)
2688 × 1520 (1 fps–25/30 fps)
Sub stream:
704 × 576 (1 fps–25 fps)
704 × 480 (1 fps–30 fps)
Stream Capability2 streams
Resolution3840 × 2160 (3840 × 2160); 3072 × 2048 (3072 × 2048); 3072 ×1728 (3072 × 1728); 2592 × 1944 (2592 × 1944); 2688 × 1520 (2688 × 1520); 3M (2048 × 1536); 2304 × 1296 (2304 × 1296); 1080p (1920 × 1080); 1.3M (1280 × 960); 720p (1280 × 720); D1 (704 × 576/704 × 480); VGA (640 × 480); CIF (352 × 288/352 × 240)
Bit Rate ControlCBR/VBR
Video Bit RateH.264: 32 Kbps–8192 Kbps
H.265: 12 Kbps–8192 Kbps
Day/NightAuto(ICR)/Color/B/W
BLCYes
HLCYes
WDR120 dB
White BalanceAuto/natural/street lamp/outdoor/manual/regional custom
Gain ControlAuto/Manual
Noise Reduction3D DNR
Motion DetectionOFF/ON (4 areas, rectangular)
Region of Interest(RoI)Yes (4 areas)
Smart IRYes
Image Rotation0°/90°/180°/270° (Supports 90°/270° with 2688 × 1520 resolution and lower.)
MirrorYes
Privacy Masking4 areas
Network
NetworkRJ-45 (10/100 Base-T)
ProtocolIPv4; IPv6; HTTP; HTTPS; TCP; UDP; ARP; RTP ; RTSP; RTCP; RTMP; SMTP; FTP; SFTP; DHCP; DNS; DDNS; QoS; UPnP; NTP; Multicast; ICMP; IGMP; NFS; PPPoE; 802.1x; Bonjour
InteroperabilityONVIF(Profile S/Profile G/Profile T); CGI; P2P; Milestone; Genetec
User/Host20
Edge StorageCloud; FTP; SFTP; Micro SD Card (support max. 256 GB); NAS
BrowserIE
Chrome
Firefox
Management SoftwareSmart PSS; DSS; DMSS
Mobile PhoneIOS; Android
Certification
CertificationsCE-LVD: EN60950-1
CE-EMC: Electromagnetic Compatibility Directive 2014/30/EU
FCC: 47 CFR FCC Part 15, Subpart B
UL/CUL: UL60950-1 CAN/CSA C22.2 No.60950-1-07
Power
Power Supply12V DC/PoE (802.3af)
Power Consumption< 7.6W
Environment
Operating Conditions–30°C to +60°C (–22°F to +140°F)/less than ≤ 95% RH
Storage Temperature–40°C to +60°C (–40°F to +140°F)
ProtectionIP67
Structure
CasingMetal
Dimensions108.3 mm × Φ122 mm (4.26" × Φ1.80")
Net Weight0.69 kg (1.52 lb)
Gross Weight0.88 kg (1.94 lb)
IMG_20200323_164601490.jpgIMG_20200323_164606964.jpgIMG_20200323_165009720.jpgIMG_20200323_165014802.jpgIMG_20200323_165019347.jpgIMG_20200323_165258889.jpg
Wall mount Bracket PFB203W
Back of bracket
Set screw that releases the mounting bracket.
Mounting bracket removed.
Space inside.
Ready to mount camera base to wall bracket
Camera base mounted with included stainless steel screws.
Run pig tail through hole and out the back.
Mount bracket to wall with tabs up.
After proper water proofing of the connection, organize cables inside wall bracket prior to mounting.
IMG_20200323_170645310.jpgIMG_20200323_170756896.jpgIMG_20200323_170829447.jpgIMG_20200323_171822925.jpg
Some still shots are varying focal length. I think my method of capture caused the slight lack of sharpness in the chart.
Camera settings at factory default, except time and channel name.
Recorded and exported from Blue Iris.
When it's at it's widest FOV, to me the image looks a tad soft. But then at other times it looks good. Doing an auto focus doesn't always seem to help.
But nighttime for a 4k, holy starlight sensor batman!
I'm impressed at the night time video's, again everything at defaults. 1/2.7 sensor shines.
Be sure to choose 4k in youtube player.
At a few different settings, including IR off.
I just bought three 5442’s (and a nvr) from Andy this past Saturday. Figures.
I think 2k of the 5442 will be fine for me, but a little upset I could have gotten these with varifocal for pretty much the same price I paid for the 5442.
how do you feel these comapre to the 5442 in low/no light situations?
Reactions: Arjun
Thanks for the review. Night video is very impressive. I'm curious about the wobble or camera shake. Is that from a loose mount?
A comprehensive comparison would be nice especially comparing to the 5442 and 5231 at night. If you can fit a 1/1.8 sensor in a fixed lens turret, I’m certain there could have been a way to fit it into this varifocal model as well. Seeing that this is a lite series model, this could have been a cost saving measure for budget users in mind. I have a funny feeling we may be seeing a 8mp 1/1.8 varifocal turret soon. I like the fact that Dahua is catering to all users in mind (I.e. budget users, pro users, etc). This model looks like a refreshed model of its predecessor.
Also,
Reactions: dcmkii
We need a comparison between the HDW5831 (includes HDW5830) Varifocal Turret and this IPC-T2831T-ZS :D I have a couple of IPC-HDW4831EM-ASE's and are not Starlight-certified
edit: 0.008 [email protected] (2831) vs 0.05Lux/F1.8 (5831)
Here are the lux ratings for the HDW5830,
0.05Lux/F1.4 (Color,1/3s,30IRE)
0.2Lux/F1.4 (Color,1/30s,30IRE)
0Lux/F1.4(IR on)
Note: Both models do not have AI. AI typically featured on the Pro models.
It's from 25mph wind gusts. I have it mounted on a portable test rig, with extra support, but the wind still affected it. It was either review it in the rain, or review in high winds. We've not had much choice of late.
Glad to see @EMPIRETECANDY’s review units still summoning the bad weather! :)
I bought a 5442 from him as well a couple of weeks ago and wanted one of these in addition to it and he said he wouldn't have stock till next month.
