Review-OEM 4mp AI Cam IPC-T5442TM-AS Starlight+
looney2ns
16,322
24,230
Evansville, In. USA
Dahua OEM IPC-T5442TM-AS from EMPIRETECANDY
4MP WDR Turret AI Network Camera
Review unit courtesy of Andy (@EMPIRETECANDY) in exchange for a fair and honest review.
Andy's ipcamtalk store: link
Andy's AliExpress store: link
Andy's Amazon store: link
Price Approximately US $160
Link to camera on Andy's AliExpress store: US $160.0 5% OFF|Aliexpress.com : Buy 2019 New Arriving IP Camera IPC T5442TM AS 4MP Starlight+ WDR IR Eyeball AI Network Camera , free DHL shipping from Reliable Surveillance Cameras suppliers on Empire Technology Co., Ltd
(price and link valid 05/31/19)
The IPC-T model number is an OEM model number specific to EMPIRETECANDY
I do apologize to @EMPIRETECANDY for taking so long to get this review up.
4MP WDR IR Eyeball AI Network Camera
Edit to add Spec Sheet. See attachment to this post.
1/1.8” 4Megapixel progressive scan CMOS
H.265&H.264 triple-stream encoding
25/30fps@2688×1520
WDR(120dB), Day/Night(ICR), 3D DNR, AWB, AGC, BLC
Multiple network monitoring: Web viewer, CMS(DSS/PSS) & DMSS
2.8mm fixed lens (3.6mm, 6mm optional) I have the 3.6mm version.
Max. IR LEDs Length 51m
Micro SD memory, IP67
Image Sensor 1/1.8” 4Megapixel progressive scan CMOS
Effective Pixels 2688(H) x 1520(V)
RAM/ROM 512MB/128MB
Scanning System Progressive
Electronic Shutter Speed Auto/Manual, 1/3~1/100000s
Minimum Illumination 0.0016Lux/F1.6 ( Color,1/3s,30IRE) 0.015Lux/F1.6 ( Color,1/30s,30IRE) 0Lux/F1.6(IR on)
IR Distance Distance up to 51m (167ft)
IR On/Off Control Auto/ Manual
IR LEDs 2
Lens Type Fixed
Mount Type Board-in
Focal Length 2.8mm,3.6mm,6.0mm
Max. Aperture F1.6
Angle of View H: 113°, V:60°/H: 89°, V:48°/H: 56°, V:31°
Optical Zoom N/A
Aperture Type Fixed
Close Focus Distance 1.3m(4.27ft)/1.9m(6.23ft)/3.8m(12.47ft)
Audio Built-in Mic.
Artificial Intelligence
Perimeter Protection Tripwire, Intrusion(Human & Vehicle classification)
People Counting/ Line crossing/ people counting, Region people counting.
General Intelligence
Event Trigger Motion detection, Video tampering , Scene changing, Network disconnection , IP address conflict, Illegal Access,Storage anomaly/Object Abandoned/Missing.
This is smaller in physical size than the 5231 series of turrets.
IMG_20190531_133337167.jpg IMG_20190531_133358240.jpg IMG_20190531_133408346.jpg IMG_20190531_133606484.jpg IMG_20190531_133616600.jpg IMG_20190531_133741485.jpg IMG_20190531_134007123.jpg IMG_20190531_134018537.jpg IMG_20190531_134022763.jpg IMG_20190531_134026424.jpg IMG_20190531_134029960.jpg IMG_20190531_134343538.jpg IMG_20190531_134348670.jpg
Recorded and exported from Blue Iris.
All settings at factory defaults, except time and channel name
I have now tested the AI portion of the cam by using IVS and Automobile (filtering out humans)
Then changed from automobile to humans (filtering out cars) and it works as designed in my non scientific setup.
IE: When setup to detect cars, I can walk through the scene and it does not record me.
When set to only humans, it doesn't pickup cars traveling through the scene.
Night video.
IR and 7.5 watt led post lamp on, then with post lamp off, IR on...factory defaults
Weird noise's in the audio is because I failed to turn off the audio noise filter.
Variety of combos, Ir on/off. Auto setting/manual shutter and gain settings. Forced color/bw.
Thanks Looney, looking forward to seeing night video and as more versions of them (Starlight +) are released, I.e varifocal and motorized zoom bullets etc IR version. Andy may be able to chime in here but curious if the lineup may be available with a black finish? My guess is the Starlight+ will be the go to series as time marches on. This particular camera may possibly be a choice for an entry cam at front door?
Reactions: looney2ns
Thanks to looney’s review! This model right now no plan to make black model.
great daytime video.
cant wait to see that starlight +power.
is this available in varifocal as well?
Right now only bullet and dome cams has motorized lens, this camera bit small, so hard to use motorized lens, same size of IPC-HDW4231EM-ASE
Ah! Now I feel quite a bit better about having just taken delivery of a 5231 :) I haven't used the varifocal on any of mine yet, but I plan to on at least one. Maybe even all three.
Thanks for the review Loony
While these new cameras don't fit the old junction boxes we used with the 5231's, am I correct in thinking they will fit the Wall Mount Brackets that were used with the 5231 cams? PFB203W
Also, do you have to have a special NVR to use the AI features of the camera?
Andy's ipcamtalk vendor forum: link
Andy's Email: kingsecurity2014 (at) 163 (dot) com
> 25/30fps@2688×1520
RAM/ROM 512MB/128MB
IR LEDs 2
Lens Type Fixed
Mount Type Board-in
Max. Aperture F1.6
Optical Zoom N/A
Aperture Type Fixed
Audio Built-in Mic.
View attachment 42990 View attachment 42991 View attachment 42992 View attachment 42993 View attachment 42994 View attachment 42995 View attachment 42996 View attachment 42997 View attachment 42998 View attachment 42999 View attachment 43000 View attachment 43001 View attachment 43002
No need to worry about the delay or slow, you are doing free for all of us,thanks to your always fantastic support and help here. @looney2ns
@looney2tns
In another review it was mentioned that this new cam can be mounted into the old surround for the 5231 which would/could mean that the exiting junction box could be used. Is this something that you can maybe check/test as I’d want to simply swap a 2 for a 4 without hopefully having to replace the junction box as well.
Does anyone have any details about the new sensor so I can research some of the technical specs and differences to the previous Sony Starvis? It's quite impressive to claim a 2x resolution increase and x3 low light sensitivity.
Reactions: mrblu
