Review - EmpireTech IPC-TPC124X-AI 1/2.7'' CMOS 4MP Thermal Network Mini Hybrid Eyeball Camera
wittaj
30,854
59,207
USA
As @EMPIRETECANDY pointed out in this thread, I have been playing with and testing the thermal camera IPC-TPC124X-AI. In particular, we wanted to see if they performed better than the previous thermal cameras that had proven unreliable if being used in mission critical situations and could this be a recommended camera.
The quick answer is yes, they appear to be triggering and logging and performing as one would expect. It opens up a lot of opportunities for wildlife watching or even better spotter cams for PTZs as I will touch on later.
Specifics on the camera can be found on the EmpireTech website.
Oh yeah before I forget, while bench testing, you can use it to check for temperature changes and leaks in the house LOL. Or use it as an expensive studfinder LOL.
While it has a new and improved chipset compared to the previous model, the GUI has remained the same GUI that most of us are familiar with (grey instead of the white new one). Which is probably good given all of the various options that are available.
A big benefit to many people here is that you can actually get this camera to trigger via IVS on animals. While it doesn’t have a check box for animals, it does allow you to uncheck the TARGET box and thus turns off the internal algorithm still trying to find people or cars like we have seen with some firmware.
The biggest benefit to thermal cameras is that they can “see” when the visible cameras cannot and at a further distance than infrared is capable of. The thermal image basically looks the same whether it is day or night or precipitating or not.
It can be pouring rain, and the visible camera could be triggering all night and/or you can’t see anything on the camera due to the rain, but you don’t see the rain on the thermal camera.
For example, we had a downpour just after I got this and here was what the visible camera looked like, while the Thermal camera looked the same as when it wasn’t raining:
A common problem we see is most people try to do too much with a field of view and are really stretching the realistic distances at night that a camera can see and trigger on and then complain that the camera didn’t trigger with a person out at distance.
Further, unless you have stadium quality light, folks can sometimes not be picked up with a visible camera at night if they are in dark clothes or the camera settings are not dialed in properly.
But the thermal sees right through that. Let’s look at some examples.
Here the thermal camera easily picked up this family of deer, while the visible camera missed it because it was too far away from the camera and in totally dark conditions (shutter 1/60):
As you can see, now would be a good time to point out that you wouldn’t be buying this camera for the visual camera. Unfortunately, it is not on the ideal MP/sensor ratio and is 4MP on the 1/2.7” sensor (although it is better than the previous model that had even worse 5MP on the 1/2.7” sensor).
In addition, it only has 1 infrared light, so it makes it tough for a totally dark location to benefit from the visual camera. It also has 1 white light LED, but most probably wouldn’t use that except as maybe active deterrence.
Let’s take a look at some other cool captures of some critters.
A small rabbit.
View attachment rabbit video.mp4
A small squirrel.
View attachment Squirrel video farther.mp4
A fox chasing a deer.
View attachment fox chasing a deer.mp4
Not a critter, but being able to “see” thru trees.
View attachment Can be seen thru trees.mp4
While Bench Testing
Before I even put an SD card in the camera or hooked up to my system, I got a text from a neighbor in the middle of the night that his car was just door checked (his dashcam) alerted him and he called the police and I happened to be up and say they hadn’t come past my house yet and couldn’t see them on my cameras.
So I propped up the camera to the window and took a look around. I apologize for the phone recording LOL, but it was all I had a the moment. This was 400-600 feet away from me and you can see the perp check the car and then run and hide in the bushes of a house when they saw the police come.
Will post video in next posts.
I have played with the options, and there are quite a bit like cellphone detection, heat, smoking, etc., along with different colors to use for thermal. I haven’t figured out yet if one is better than the other.
I got to test out the smoking detection with some neighborhood kids that have been sneaking out Saturday nights recently with their parents cigarettes. I set this up to trigger just on smoking detection and this was the only trigger all night, and what is impressive is they were 130 feet away from the camera:
I then moved it to an area that had some infrared blasters to see how well it could see. While better than just the single infrared, you can see how much light is needed on the visual to get it to work. This visual image has the single infrared of the camera on it along with a CMVision IR130-198 LED Indoor/Outdoor Long Range 300-400ft IR Illuminator and the image is still fairly dark, but still somewhat usable.
As a spotter cam
Here is where I think many of will find great use for this.
A common problem is to do a fixed spotter camera well, many of us have to use a bullet like the Z4E or Z12E in order to make the object large enough for IVS to trigger. So we end up having cameras that clearly are not pointed on our property hanging on the house. This camera being a turret isn’t as obvious.
Furthermore, due to infrared limitations, we probably cannot spot as far away as we would like. I know I would like to be able to get as much of the person on my PTZ as soon as possible and from further away as well.
My existing spotter cams are able to reliably get me an additional 75 feet off of my property for the PTZ to swing to and start tracking (shown in red).
With the thermal camera, since it doesn’t need light, I was able to reliably get the thermal to trigger for human 400 feet away (shown in green). Now of course my PTZ at night struggles at that distance due to the lack of light, but I was able to get it to consistently be able to track at night at the 150-200 foot range. That extra 75 to 1215 feet of extra distance allows me to get more of a straight on shot than a side shot of the person previously. Any time we can track a perp earlier the better.
Now of course, your situation will vary. Obstacles in the way like trees and other houses will limit the distance, along with available lighting and PTZ capabilities, but I would think that in every instance the thermal camera will allow for a further distance away for a spotter camera to trigger.
In summary, I think a thermal should be considered in most applications. Even if you don't use it as a spotter cam, the ability to see and track things that you cannot see further out is a great benefit. It can help piece together events when the action was beyond the reach of infrared.
Thanks @wittaj great review,
This is how to make the camera firm alarm work guide video.
Thanks @wittaj great review, we can also change the color mode on camera. Can make it too green.
Yeah there are like 18 different color modes. I am testing each one to see if one is better than the other as it relates to IVS triggers.
I picked the green because that is what Night Vision Goggles look like LOL.
Pretty impressive. I have a dozen spots for 12 of them, but I have to hope the price comes down first.
I tested the animals specifically with you in mind with your wildlife 5442 thread. I figured if there was a camera that would be ideal for watching wildlife and maybe Finding Bigfoot LOL, this would be the one.
The great thing about the thermal is you can make the min object size pretty small and the only triggers were for any living object that size or larger. None of the leaves blowing around triggered it. And the trees have been losing leaves bigger than the min size I picked out. I tested it with the visual one and all the leaves falling were triggering.
The prices have come down a lot, so not sure how much more it could go down, but the first versions were selling for around $800.
1699578455846-png.177499
When I saw this picture, my first thought was that I hope the deer don't jump off the cliff.
The specs list the thermal resolution as 256 (H) × 192 (V). Is the resolution of the thermal measured differently somehow? That's the size of a high quality desktop icon. Some of the images, like the deer upclose, do look pixelated but it still looks larger that 256x192.
I pulled those from the Win10 Snip tool, so the box I drew could have been off a bit. But they are basically a 4:3 ratio, so they stick out in BI compared to the other cameras.
I tend to run the NR lower than most, so that probably explains some of the pixelated look.
I will pull a snapshot out of the GUI so you can see it in its native form.
There is still some adjusting I can do to make the thermal more crisp, but I was moving it around to different spots so I didn't want to have to go thru that process each time.
Reactions: EMPIRETECANDY
One question:
There was a video in the other thread where you see both channels side by side
Both channels have different rules but only the thermal channel triggers.
Is this the normal behaviour ?
One question:
Yes both cameras are independent of one another for triggering. So you can do IVS with min size for thermal (to catch wildlife) and human IVS for visual (small min size on visual camera results in tons of triggers for leaves and shadows, etc. that the thermal doesn't see). Or SMD for one and nothing for one.
Also, this does count as two channels for VMS purposes like an NVR.
That video you are referring to in the other thread showed how based on camera settings someone could walk thru a visual field of view and not trigger if the the image is too dark or the visual settings are not dialed in to the field of view, just like we see in some threads here where people come for advice because their camera isn't triggering at night with infared.
