Intro
This is the first of 3x S3 reviews. This one will focus on the EmpireTek IPC-T58IR-ZE-S3 - 8MP S3 Turret Camera / IPC-HDW5842T-ZE-S3 Turret Camera. Unit has been provided by Andy @EMPIRETECANDY (THANK YOU !) in exchange for my fair and unbiased review.
This cam is an 8MP unit with IR. Critically these S3 units feature a number of upgrades to previous S1 / S2 versions such as AcuPick 2.0 , SMD 3.0, EPTZ as well as some great staples such as Video Metadata (which you know I’m a big fan of). It does this with a new SOC that without spoiling anything, handles things very well. It features an impressive 4 streams (1 main, 3 subs), 2 of which can handle up to 30fps @ 1080p making this a great option for sub stream sharing with additional smart home options such as Home Assistant, HomeKit, Scrypted etc which is great from a flexibility perspective, over and above traditional MW and NVR usage.
Another critical feature to point out is that these S3 cams (turret + bullet cam variants) now feature built in Microphones which has been a LONG time coming and I’m very happy this is now included.
It’s also worth noting that with the update to IVS / SMD 3.0 we now get Animal’s as a Target option. While this is great to see, I have to point out that at this point in time (July 2024) that Dahua does not offer any way to filter Animals in cam or NVR at this time. I’ve fedback that similar to Video Metadata where you have the option to filter by Human, Motor Vehicle, Non-Motor Vehicle, that we need an option to filter IVS by Animals IF this feature is going to be useful for users / evidential review.
As I mentioned in my opener post (How about a new review, what about 2, 3, possibly 4 ?), I’ve also noticed issues with AcuPick 2.0 AI algorithms relating specifically to HumanTrait. Specifically a LOT of incorrect ‘targets’ being captured with this latest algorithm that results in 100’s / 1000’s of images / vid caps. I’ve already filed this bug with detailed testing plans, recommendations etc and am awaiting updated FW from Dahua so I can perform additional testing. Therefore in the meantime, while I’ll mention AcuPick 2.0, I am purposefully NOT going to focus on that in this review and will post an addendum later. For the record, Video Metadata works fine on these cams, just not AcuPick 2.0, its AI alogirthms and therefore incorrect meta tagged files.
As usual I will be covering configuration, AI setup for critical capture, tips and tricks on how to best utilize and obviously a rundown of image quality in day/night capture scenarios. Initial vids and pics in post 2, AI feature breakdown and testing in post 3, tips and tricks on how to make these features work and other settings / menu functions in post 4 and a summary of findings / recommendations in post 5.
If anyone has any questions as I go just leave a comment. Please remember to keep questions/comments on topic with this thread. Thanks
Onto the specs
Firmware Installed On Delivery - 2024-05-16 - Current version for this review: 2024-05-24
GUI
Uses the new Web 5.0.1
Camera Details
Image Sensor - 1/1.8” 8 Megapixel STARVIS™ CMOS
Effective Pixels - 3840(H) x 2160(V), 8 Megapixels
Electronic Shutter Speed - 1/3s~1/100,000s
Minimum Illumination:
IR LEDs - 2
IR Distance - Up to 40m (131.23 ft)
IR On/Off Control - Manual/Auto + Smart IR = Off / General (General is my recommendation)
Lens Information
Focal Length - 2.7mm~12mm
Max. Aperture - F1.8
Field of View
Optical Zoom - 2.7mm to 12mm
Close Focus Distance - 1.5m (4.92ft)
DORI Distance
Wide
Tele
Mounting Options
Onto the specs
GUI
Camera Details
RAM: 2GB
ROM: 4GB
Color: 0.0008 [email protected];
B/W: 0.0004 [email protected];
0Lux (IR on)
IR LEDs - 2
Lens Information
Field of View
H: 113° ~ 47°
V: 60° ~ 26°
D: 133° ~ 53°
DORI Distance
Wide
Detect - 83.4m(273.62ft)
Observe - 33.4m(109.58ft)
Recognize - 16.7m(54.79ft)
Identify - 8.3m(27.23ft)
Tele
Detect - 189.6m(622.05ft)
Observe - 75.8m(248.69ft)
Recognize - 37.9m(124.34ft)
Identify - 19.0m(62.34ft)
Mounting Options
- PFA122 - Square 3 hole junction box
- PFA137 - Circular Junction Box
- PFB203W - Wall Mount Bracket
- PFA152-E - Pole Mount Bracket
- PFB220C - Ceiling Mount Bracket
