Courtesy of Andy @ Empire Technology @EMPIRETECANDY we have a new Mini PTZ to check out.
This is similar to the one that @tangent reviewed, except this one includes zoom and IR illumination, his model does not.
You can see his review here of the SD12200T-GN: Review: Dahua Starlight Mini PT Dome SD12200T-GN
This camera, the SD1A203T-GN, that I'm reviewing is from Dahua's EcoSavy 3, Lite series of cams.
This camera was provided by Empire Technology in exchange for a fair and honest review.
Specs:
Image Sensor 1/2.8” STARVIS™ CMOS
Effective Pixels 1920(H) x 1080(V), 2 Megapixels
RAM/ROM 512M/128M
Scanning System Progressive
Electronic Shutter Speed 1/1s~1/30,000s
Minimum Illumination Color: [email protected]; [email protected] (IR on)
S/N Ratio More than 50dB
IR Distance Distance up to 15m (49.2ft)
IR On/Off Control Auto/Manual
IR LEDs 3
Focal Length 2.7mm~8.1mm
Max. Aperture F1.8
Angle of View H: 105.6° ~ 35.2°
Optical Zoom 3x
Focus Control Auto/Manual
Close Focus Distance 100mm~ 1000mm
More specs here: http://www.dahuasecurity.com/asset/upload/product/20180118/SD1A203T-GN_Datasheet_20180118.pdf
Price as of this writing $170.00 shipped via DHL.
Can be purchased here: Aliexpress.com : Buy SD1A203T GN 2MP 3x Starlight IR PTZ Network Camera SD1A203T GN, Free DHL shipping from Reliable network camera suppliers on Empire Technology Co., Ltd
Body is all metal except for the dome and the black area that covers the IR's.
The web interface is pretty much standard Dahua Interface.
Upon logging into the cam for the first time, I did notice they have added additional nag screens.
The first one is to ensure you enter a strong password.
Then they want you to add your email address in case of password recovery.
Then a prompt to turn on Easy4IP, and sign up for their P2P service.
Also one to turn on automatic firmware upgrades. (my opinion, just say no)
My opinion is to skip adding your email address, nor enable Easy4ip for security reasons.
Firmware is dated 12/27/17.
Unless someone just HAS to see it's guts, I will refrain from taking the cam a part, as I assume it's very similar to the version that tangent is reviewing.
Cam and included accessories. Camera has a built-in mic, as well as an audio input and output on the pigtail. Once I get to the video's, you will hear why you may want this option, it's noisy with the built-in mic when moving.
Without mounting plate.
With mounting plate.
Door off for reset button, and SD card install.
SD card ready to be locked in.
SD card locked.
Specs:
RAM/ROM 512M/128M
IR LEDs 3
Max. Aperture F1.8
Optical Zoom 3x
SD card locked.
