Review-Dahua IPC-K35A 3mp Cube Camera
looney2ns
16,322
24,228
Evansville, In. USA
Courtesy of @EMPIRETECANDY at Empire Technology Co., Ltd - Small Orders Online Store, Hot Selling and more on Aliexpress.com | Alibaba Group and https://amzn.to/2wunK9a and EmpireTech Andy | IP Cam Talk.
We have the 3mp IPC-K35A 3mp indoor cube camera to check out. This was a return from a customer of @EMPIRETECANDY and Andy graciously had the customer send it to me.
I have received this camera in exchange for a fair and honest review.
It can be purchased for approx $77us shipped here: US $76.94 5% OFF|Aliexpress.com : Buy IPC K35A 3MP K Series PoE Network Camera IPC K35A free shipping from Reliable network camera suppliers on Empire Technology Co., Ltd
This is from Dahuas Consumer line of cameras.
> 1/3” 3Megapixel progressive CMOS
> H.264 & MJPEG dual-stream encoding
> 20fps@3M(2304x1296)&25/30fps@2M (1920×1080)
> 100° horizontal view angle
> IR Distance 10m
> Cloud Support
> Micro SD card slot, up to 128GB
> Alarm in/out,PIR
> DC12V, PoE
> Two-way Talk
Product page: IPC-K35A | Dahua Technology
Full spec sheet here: https://www.dahuasecurity.com/asset/upload/product/20180929/DH-IPC-K35A.pdf
User manual here: https://www.dahuasecurity.com/asset/upload/download/DH-IPC-K35A_QSG_20161219.pdf
This could be a very discreet camera for indoor use.
IMG_20190328_130014620.jpg IMG_20190328_130136237.jpg IMG_20190328_130218708.jpg
Sd card slot
IMG_20190328_130227003.jpg IMG_20190328_130251528.jpg IMG_20190328_130301963.jpg
That looks exactly like the Annke (HikVision) Cube Cam!
Mark
Sent from my iPhone using Tapatalk Pro
if its anything like the hik camera.. its great. great image quality for inside use.
Thanks for another fantastic review Looney. I know it takes a lot of time. Great to have Andy supply his wares for review, what a great seller. May have to try one of these for the garage.
@looney2ns always bring us super testing review, thanks.
Reactions: looney2ns
I seem to be missing something in the review.
Does the K35 have wifi (i think not) ?
Does the K35 have a good web based configuration interface ?
Does this work easily with BI or are there problems ?
Are there any negatives with this camera for inside use.
1-this model no wifi, see the K35S model for wifi version
2-Yes
3-Yes
4-None I came across.
Trying to get this camera to work with 2 way audio via my android phone. Tinycam pro apparently does not support 2 way audio for this camera.
Does anyone know of another android phone app that I could use so the talk feature works? (listen works great)
Tampy
Which one of these do you like more Looney? I have about 9 Annke ones for indoors, and though they are good enough, curious to know your thoughts of the Dahua compared to the Annke one in terms of video/audio quality. and if it is worth the upgrade?
