Review-Dahua IPC-HDBW4239R-ASE full color camera
looney2ns
16,757
24,984
Evansville, In. USA
Courtesy of @EMPIRETECANDY at Empire Technology Co., Ltd - Small Orders Online Store, Hot Selling and more on Aliexpress.com | Alibaba Group we have the new IPC-HDBW4239R-ASE full color cam to check out.
Product page: IPC-HDBW4239R-ASE
Spec Sheet: https://www.dahuasecurity.com/asset...9/DH-IPC-HDBW4239R-ASE_Datasheet_20180511.pdf
2MP WDR Full-color Starlight Dome Network Camera
> 1/2.8” 2Megapixel progressive scan STARVIS™ CMOS
> H.265&H.264 triple-stream encoding
> 50/60fps@1080(1920×1080)
> Smart Detection supported
> WDR(120dB), Day/Night(Electronic), 3DNR, AWB, AGC, BLC
> Multiple network monitoring: Web viewer, CMS(DSS/PSS) & DMSS
> 3.6mm fixed lens (6mm optional)
> 1/1 Alarm in/out, 1/1 audio in/out
> Micro SD memory, IP67, IK10, PoE
Image Sensor 1/2.8” 2Megapixel progressive scan CMOS
Effective Pixels 1920(H) x 1080(V)
RAM/ROM 256MB/32MB
Scanning System Progressive
Electronic Shutter Speed Auto/Manual, 1/3~1/100000s
Minimum Illumination 0.001ux/F1.0 ( Color,1/3s,30IRE) 0.006Lux/F1.0 ( Color,1/30s,30IRE)
S/N Ratio More than 50dB
IR LEDs N/A
Lens Type Fixed
Mount Type Board-in
Focal Length 3.6mm (6mm optional)
Max. Aperture F1.0(F1.0)
Angle of View H: 87°/54°, V:47°/20°
Optical Zoom N/ A
Focus Control Fixed
Close Focus Distance 1.6m(5.3ft)/3.5m (11.5ft)
This cams claim to fame will hopefully be the aperture of F1.0, wide open aperture should let in lots of light.
As usual, the cam is in an all metal case.
Camera Porn:
20180814_134437.jpg 20180814_134354.jpg 20180814_134312.jpg 20180814_134325.jpg 20180814_134812.jpg 20180814_134820.jpg
Sd Card Slot
Factory Reset Button
Lens Rotates and tilts within the gimble.
The Driveway to the right of the cam is very dark to the naked eye. Most of the street directly in front of the cam is also very dark to the naked eye.
First house to the right with a porch light on, that's a single 60watt bulb.
The next house to the right, that is two 75w equal LED flood lights.
Next two houses, single porch light.
Again, the light coming from the the left of my driveway is 7.5watts of LED light in a post lamp.
All camera settings at factory default.
B&W at night.
It is not seeing the IR that I have in the front yard, that is why I assume it has no IR cut filter.
The color video to me is better than the B&W
Only reason I don't hate domes now, is because of my new mini ptz and I can get factory direct replacements. I tell anyone that uses domes, pre-order how ever many you think you might need upfront and store them away.
are the tighter zoomed segments the same cam in a second location?
Gotta be careful of those ghost deer.. :D
Reactions: looney2ns
That was very creative, staging that deer walking through your yard........ :)
P.S. thanks for the video as usual..
Edit: Perhaps I should stop watching your reviews, NOW I want one............
So it has no built-in IR at all, right? Does it have an IR-cut filter and respond to IR (if using exeternal IR)?... thanx.
so IR doesn't help it at night? it relies solely only on visible light?...
if IR makes any difference to the night picture, then it must be IR-sensitive, and if that's the case,
it must have an IR-cut filter for the daytime, or the daytime colors would be off (pink/purple-ish),
unless they've come up with some way to do that in software to save the cost of a HW IR filter. hm...
the specs for color mode do look impressive, 5x more sensitive than the 5231 and 2231.
Does it seem to live up to that, in your experience? thanx.
I know my 22204TNI 2MP Starlight mini ptz has an ir cut filter even though it doesn't have ir. I tested it and the camera does switch to b/w and remains to give a nice clear picture.
This kind of cam suits for the area with good light place and can show up the color pic, the sensors is very good, i think one day the cams can work real good at star light without any IR light. This cam not suits for the totally dark places.
