Review- Dahua IPC-1435S-W-S2 4mp 3.6mm WiFi bullet cam
looney2ns
16,668
24,822
Evansville, In. USA
Dahua IPC-1435S-W-S2 4mp 3.6mm from @EMPIRETECANDY
Review unit courtesy of Andy (@EMPIRETECANDY) in exchange for a fair and honest review.
Andy's ipcamtalk vendor forum: link
Andy's AliExpress store: link
Andy's Amazon store: link
Andy's Email: kingsecurity2014 (at) 163 (dot) com
Price Approximately US TBD
Purchase from Amazon here: TBD
Andy's Aliexpress store here: TBD
Please try to keep this thread on topic
4MP IR Bullet WI-FI Camera
4MP, 1/3” CMOS image sensor, low illuminance, high image definition
Outputs max. 4MP (2560 × 1440) @20 fps
H.265 codec, high compression rate, ultra-low bit rate
Max. IR distance: 30 m
ROI, SMART H.264/H.265, flexible coding, applicable to various bandwidth and storage environments
Rotation mode, WDR, 3D DNR, HLC, BLC, digital watermarking, applicable to various monitoring scenes
Supports 256 G Micro SD card
Requires 12V DC power supply, not included. No POE.
No microphone
IP67 protection
Supports Wi-Fi or ethernet.
Link to full Spec Sheet
Image Sensor1/3”4Megapixel progressive CMOS
Max. Resolution2560 (H) × 1440 (V)
ROM128 MB
RAM256 MB
Scanning SystemProgressive
Electronic Shutter SpeedAuto/Manual 1/3 s–1/100,000 s
Min. IlluminationManual 1/30 s
0.9343 Lux @F2.0 (Color, 80 IRE); 0.9258 Lux @F2.0 (W/B, 80 IRE); 0 Lux (IR on)
Manual 1/3 s
0.1195 Lux @F2.0 (Color, 80 IRE); 0.1190 Lux @F2.0 (W/B, 80 IRE); 0 Lux (IR on)
S/N Ratio>52 dB
Illumination Distance30 m (98.4 ft)
Illuminator On/Off ControlAuto
Illuminator Number18 (IR LED)
Pan/Tilt/Rotation RangePan: 0°–360°
Tilt: 0°–90°
Lens
Lens TypeFixed-focal
Mount TypeM12
Focal Length2.8 mm
3.6 mm
Max. ApertureF2.0
Field of View2.8 mm:
Horizontal: 97°
Vertical: 52°
Diagonal: 116°
3.6 mm:
Horizontal: 76°
Vertical: 42°
Diagonal: 90°
I wanted to test this cams Wifi ability, since we all foo foo, using wifi for security cams. I mounted it to a tree in the backyard watching over the critter feeding area. That puts it about 55', 5 walls, brick veneer on the house, and foil faced insulated sheathing away from the router. I had to tone it down to h265, 13fps, 1024 bitrate to keep it connected at all. ;) With that setup, I ran it 3 days to count how many dropouts BI would log. It dropped out 38 times. You can see freezes in the video also. All it took to make it drop out was for me to place my hand within 6" of the cameras Wifi antenna.
It's a decent little camera for the right area. Note that the area it's looking at also has IR from the PTZ on the roof to supplement the cams own weak IR.
Video recorded and exported from Blue Iris.
@looney2ns Thanks!
I have a client said can't find the ip address for this wifi camera, and can't add to BI.
Do you have any guide?
Andy
@looney2ns Thanks!
Andy
I'd suggest he set it back to factory defaults, then try the 192.168.1.108 address again.
He may want to use config tool if he still can't find it. He needs to read the config tool instructions.
It needs to be setup using a network cable first, not via wifi.
Reactions: EMPIRETECANDY
