Review-8mp 4mm EmpireTech OEM turret
looney2ns
16,356
24,275
Evansville, In. USA
EmpireTech IPC-T2385G-I 4mm hikvison oem 8MP, 4 mm from @EMPIRETECANDY
This is a Hikvision OEM with @EMPIRETECANDY model #
Review unit courtesy of Andy (@EMPIRETECANDY) in exchange for a fair and honest review.
Andy's ipcamtalk vendor forum: link
Andy's AliExpress store: link
Andy's Amazon store: link
Andy's Email: kingsecurity2014 (at) 163 (dot) com
Price Approximately US $150.00-$160.00
Purchase from Amazon here: Link
Andy's Aliexpress store here: Link
Links and price valid 12/25/20
Please try to keep this thread on topic
8 MP IR Fixed Turret Network Camera
• Up to 8 megapixel high resolution
• Max. 3840 × 2160@20fps
• 2.8 mm/4 mm fixed lens, optional
• H.265, H.265+, H.264+, H.264
• 120dB WDR
• 12 VDC & PoE (802.3af, class 3)
• IR range: Up to 30 m
• Support on-board storage, up to 128 GB
• IP67
• BLC/3D DNR/ROI/HLC
• Color: 0.008 Lux @ (F1.2, AGC ON), 0.016 Lux @ (F1.6, AGC ON)
Camera
Image Sensor: 1/2" Progressive Scan CMOS
Signal System: PAL/NTSC
Min. Illumination: Color: 0.008 Lux @ (F1.2, AGC ON), 0.016 Lux @ (F1.6, AGC ON)
Shutter time: 1/3 s to 1/100,000 s
Slow shutter: Support
Lens: 2.8 mm, horizontal FOV: 102°, vertical FOV: 55°, diagonal FOV: 120°
4 mm, horizontal FOV: 78°, vertical FOV: 43°, diagonal FOV: 92°
6 mm, horizontal FOV: 50°, vertical FOV: 27°, diagonal FOV: 59°
Lens Mount: M16
Adjustment Range: Pan: 0° to 360°, tilt: 0° to 100°, rotate: 0° to 360°
Day& Night: IR Cut Filter
Wide Dynamic Range: 120 dB
Digital noise reduction: 3D DNR
Focus: Fixed
Compression Standard
Video Compression: H.265+/H.265/H.264+/H.264/MJPEG
Video bit rate: 32Kbps~16Mbps
Triple Streams: Yes
Max. Image Resolution: 3840 × 2160
Frame Rate: 50Hz: 20 fps (3840 × 2160), 25 fps (3072 × 1728, 2560 × 1440, 1920 × 1080, 1280 × 720)
60Hz: 20 fps (3840 × 2160), 30fps (3072 × 1728, 2560 × 1440, 1920 × 1080, 1280 × 720)
Sub Stream: 50Hz: 25fps (640 × 480, 640 × 360, 320 × 240)
60Hz: 30fps (640 × 480, 640 × 360, 320 × 240)
Third Stream: 50Hz: 25fps (1280 ×720, 640 × 360, 352 × 288)
60Hz: 30fps (1280 ×720, 640 × 360, 352 × 240)
Image Enhancement: BLC/3D DNR/HLC
Image Settings: Rotate mode, saturation, brightness, contrast, sharpness and white balance adjustable by client software or web browser
ROI: Support 1 fixed region for main stream and sub stream separately
Day/Night Switch: Day/Night/Auto/Schedule
Network
Network Storage: microSD/SDHC/SDXC card (128G), local storage and NAS (NFS,SMB/CIFS), ANR
Protocols: TCP/IP, ICMP, HTTP, HTTPS, FTP, DHCP, DNS, DDNS, RTP, RTSP, RTCP, PPPoE, NTP, UPnP, SMTP, SNMP, IGMP, 802.1X, QoS, IPv6, UDP, Bonjour
General Function: One-key recovery, Anti-Flicker, three streams, heartbeat, mirror, password protection, video
mask, Watermark, IP address filtering
System Compatibility: ONVIF (Profile S, Profile G), ISAPI
Interface
Communication Interface: 1 RJ45 10M / 100M Ethernet interface
On-board storage: Built-in Micro SD/SDHC/SDXC slot, up to 128 GB
Reset Button: Yes
Smart Feature-set
Behavior Analysis: Line crossing detection, Intrusion detection, Unattended baggage detection, Object removal detection
Line Crossing Detection: Cross a pre-defined virtual line
Intrusion Detection: Enter and loiter in a pre-defined virtual region
Unattended Baggage: Objects left over in the pre-defined region such as the baggage, purse, dangerous materials
Object Removal: Objects removed from the pre-defined region, such as the exhibits on display.
Exception Detections: Scene change detection
Recognition: Face Detection
General
Operating Conditions: -30 °C ~ 60 °C (-22 °F ~ 140 °F)
Humidity 95% or less (non-condensing)
Power Supply: 12 VDC ± 25%, 5.5 mm coaxial power plug ,PoE (802.3af, class 3)
Power Consumption: 12 VDC, 0.7 A, max: 7.5 W
PoE: (802.3af, 36 VDC to 57 VDC), 0.3 A to 0.2 A, max: 9 W
Weather Proof: IP67
PXL_20201220_203830012.jpgPXL_20201220_204333816.jpgPXL_20201220_204344436.jpgPXL_20201220_204407397.jpgPXL_20201220_204501811.jpgPXL_20201220_204550245.jpg
All videos exported from Blue Iris. Settings exposure set to 1/60 at night.
It does well in most instances, except when forced to color at night. Then as most 8mp's do, it goes in the dumper.
Note: This camera does not include audio.
Would be a great camera in color if you have enough white light.
It doesn't do too bad at night in B&W with and without IR.
Thanks for taking the time to do this review, looney. :)
