How is this versus the 2mp model that we all have come to love?The OP has been corrected, with new videos and info.
The camera is fine, it was my goof's that caused the original reported issues'.
@EMPIRETECANDY
This one is better after dark.How is this versus the 2mp model that we all have come to love?
Review-IPC-E3241F-AS-M Loryta (dahua) 2mp 2.8mm mini dome.
Loryta IPC-E3241F-AS-M 2.8mm from @EMPIRETECANDY 2MP Mini Dome Network Camera This is a Dahua OEM with @EMPIRETECANDY model # Review unit courtesy of Andy (@EMPIRETECANDY) in exchange for a fair and honest review. Andy's ipcamtalk vendor forum: link Andy's AliExpress store: link Andy's Amazon...ipcamtalk.com
Anybody know if the camera can be mounted to a ceiling and camera aimed perfectly horizontal or even a degree or two upwards?
Not sure if you have big 1"inch holes through the hardi plank into the wall cavity behind to hide the connector, but that is what you would have to do. then apply a bead of duct seal around big 1" hole and squish it tight to seal perimeter when mounting camera to the board with plastic anchors and screws. then stuff some more duct seal in smaller hole on top side of camera.Has anyone tried wall mounting this camera without a bracket in a location that gets rain? I need to replace a couple of old Hik mini-domes that I mounted vertically on Hardiplank and have been torrentially rained on without complaint for 5+ years. I could probably replace with Dahua turrets (since their electronics are completely sealed in the rotating ball) but like the smaller, less obtrusive mini-dome form factor.
Gardner Bender 1 lb. Plug Duct Seal Compound DS-110 - The Home Depot
Gardner Bender Duct Seal Compound Plug helps seal conduit openings, holes against drafts, dust, moisture and noise. Easy to handle.www.homedepot.com
