I have 2 IP cameras with one that is mounted upside down that works fine. On the other one that is mounted upright the picture is upright but using Blue Iris the pan and tilt controls are reversed. With the software that came with the cameras both work like they are supposed to work but I can't understand why if the picture is upright why are the controls reversed. There is an upside down setting with the original software but it not only reverses the picture but also the controls are reversed and that one is working correctly with BI. But the other camera is set for normal mounting right side up. I could understand if the BI interpreted it wrong but then the picture would also be upside down and that's not the case. The picture is correct, only the pan and tilt are reversed.
I'm a new licensed user of Blue Iris so haven't totally figured out all the things you can do with this program. Is there a setting in BI to reverse ONLY the controls?
Thanks in advance for any help.
Jerry in NW Florida
Jerry in NW Florida
