Initial setup of a Dahua DH-SD22204T-GN mini PTZ dome camera. This is a generic no label camera purchased from Ali-Express. The camera is NTSC and has English firmware. I do not know if it is a China region camera or not.
From within the firewall I have full access to the camera and all settings and it appears to work as expected. The camera is connected direct to the router on the LAN. When I first logged on the camera asked for the browser plugin to be installed. Power is provided with a single channel POE injector and access is via Firefox on both Windows 10 Pro and Windows 7 Pro computers.
Access from outside the firewall is where the problem occurs. I am using the NOIP DDNS service. On first access the camera asks for the browser plugin to be installed. Second access gets me to the login screen for my username and password. The full control panel comes up with access to the settings and etc. and I can control the PTZ functions. In the window where I expect to see the picture is a message Resource is limited, open video failed! My first reaction was to cut down the main stream resolution, disable the sub streams, and limit the data rate. That did not help.
Any thoughts would be appreciated.
