Resolution Changing Itself
Stephen Drake
Jun 12, 2017
116
5
Hey guys,
Does anyOne have any idea why my cameras might be changing the resolution? I lost control of one of my cameras so I logged into the others to see if I could still access them. I just happened to notice that both of the cameras that I still have control of our set down to 12 80 x 7 20 They are four megapixel cameras and I know I said them at the 26 88 x 1 520
Thanks!
If you have these connected to an NVR, I have heard of the NVR overwriting camera settings before. You'd need to change the resolutions within the NVR instead of within the camera, I think.
Sorry for that last reply. I was trying to use voice to dictate it. I somehow changed the IP address of a camera to the external ip of my network. Now I cannot log in to reset the camera. Unfortunately I do not have a windows computer and cannot download the SADP tool. Any idea how I could fix this?
what are you using to access the camera?
Change the IP address of whatever you are using to the same network as your camera, and then log in to the camera and change the IP address back.
The IP address I used is my external IP address. It is set to static. I'm guessing I change to dynamic and request a new ip? Sorry, I'm not great with network stuff.
