Hivision isnt responding in getting my admin password reset despite sending them the xml file
If i do a factory reset as i am able to logon to the NVR as i have the unlock pattern but no password
in order to set up lan/.wan access to nvr i require to logon using the admin password
doe the reset also reset the admin password
If it does what is the default password
