Hi all,
I'm new with all things ip camera, but i'm comfortable enough with anything with a wire that i thought i could tackle this myself: guess not.
The environment:
DS-7716NI-I4/16P NVR (Factory Reset)
Unmanaged Netgear POE switch
About 22 IP camera's (all Hikvision)
The problem:
Not one camera is getting online, whatever i try
What i have tried:
Factory Reset NVR
Hard Reset Camera
Factory Reset Router
SADP tool / NVR
Connect (reset) camera to router (so i could set up using sadp)
-> Camera doesn't seem to get an IP from my router.
-> Tried different router (with nothing connected but laptop and one camera); same result
-> Tried different ip pools (192.0.0.64, 192.168.1.*, 192.168.1 etc. etc.)
Sometimes i can see a camera popping up in the dhcp table, but it doesn't show up in SADP or web interface
Connect to NVR
-> Factory Reset NVR
-> Reset camera
-> Connect direct on PoE port on NVR, camera just stays on 'Detecting' (Plug & Play)
So far i think the whole problem starts with the camera's not getting an IP; from either the NVR or my router.
What am i missing here? Hope you guys/girls can help me out because i'm chasing my tail here.
The environment:
The problem:
What i have tried:
Factory Reset NVR
Hard Reset Camera
SADP tool / NVR
Connect to NVR
-> Reset camera
