Hi everyone,
Looking for a bit of advice. I'm a security camera newbie as I've never seen the need before until some recent incidents. I've taken a skim through the "Cliff notes" and some other bits but these seem to have been written more from the point of view of wanting to put cameras all around a detached house where you can be sure of the camera seeing an intruder before they get close to the house. Living in a mid-terrace house I'm not quite sure how much that will affect choice of camera, especially as I think it's going to be possible to get into my back garden quite close to the back of my house. I'm also wanting to avoid going overboard with cameras, and especially to avoid developing security camera GAS.
Background
Since the start of December there've been a couple of incidents of theft, antisocial behaviour and trespass around my house. In the diagram my house is B.
In December, neighbour C had one of his sheds broken into. Coincidentally, or not, this was not too long after he'd recently started keeping some new tools in there. Since Christmas, my neighbour at house E also had stuff stolen from his shed (amazingly, I learned he never even used to keep his shed locked until this incident).
From the end of February, there have been three further incidents where things were thrown into gardens A, B, C, E and F, and neighbour C caught an intruder on the camera he had installed after the first of these incidents. I've not seen the footage of that as, not being too tech savvy, he managed to delete it as well as the "good" image his camera captured by mistake. I've only seen the image below, which frankly isn't much use as his security light has completely blown out the intruder as they were close to his conservatory where the light is mounted. However, I'm told that in the video clip his camera did capture all you could make out that it was someone in a hoodie; the picture wasn't good enough to make out the face. (I'm not sure what camera he's using but as he said it only cost him £50 I'm guessing that it's probably not a particularly decent spec.)
The latest incident is of particular note as the camera apparently didn't begin with the intruder heading towards the house but walking away from it before coming back. This has lent a bit of weight to a theory/concern that C and I have that on at least one occasion someone may have walked up from the roadside between C and D's houses and climbed up onto the outside toilets and then come across his conservatory roof (or that someone has been climbing up onto the outside toilet roof from D's garden). We had this suspicion because after the end of February incident he found a blob of ice cream on his conservatory roof; we weren't sure if it had been thrown from D's garden, or dropped by someone who had climbed up onto the outside toilet/conservatory roof. Prior to the incident on 15th March neighbour C tells me his camera caught something moving on his conservatory rood, but it was too close to tell what (his camera is mounted too high for it to have been a cat which would otherwise have been my first guess)
Details of area needing cover:
Main points of consideration:
Background
- Back garden, roughly 6m wide by 16m long (garden is about 20m long at the longest point but two sheds at 16m from the rear of the house block almost all view of the remaining bit)
- There's fencing nearly all the way round, although height varies. It's mostly 6ft apart from 3 5ft panels on the right closest to the house and 1 6ft, 3 4ft, and 2 5ft panels on the left. The 4ft panels have mesh fastened to the posts above them to restrict access over them, while the 5ft ones have trellis fastened across the top for the same reason.
- The only spot where there's no fence is where the outside toilet is, which backs on to house A's outside toilet. There's a door to the shared passageway that runs to the front of the houses there. The door is locked (as is A's door opposite it) and the door at the front of the passageway is also locked.
- Therefore the easiest route into the garden would be over the shorter sections of fence on the right, running about 6m from the back wall of my house. Realistically, someone trying to get into my garden would probably try coming over the 2nd or 3rd panel from the back of my house, so we're looking at a zone of 2-6m.
- Although I want to ensure my back door is covered, as well as the door to the passageway shared with A that runs to the front of the house, I suspect any potential thief will be more interested in trying to get into the sheds in the hope of finding tools to steal.
- I have a centrally located security light on the back wall. This only seems to trigger as you pass a point about 5m from the back wall of my house, so if someone were able to get into the garden more than 5m from the house, my light wouldn't illuminate them. A and C have security lights which do get triggered by movement in my garden but probably not enough illumination to be of use to a security camera.
- I would assume if going with only a single camera, the best position for it would be above my back door as that's the only spot you can really see all of the garden in front of the sheds (as per wide view below)
- I think the key thing for me is that any camera(s) bought can generate images capable of identifying an intruder, whether at my shed door or back door.
- As the incidents that have prompted this search have occurred at night time, and I work from home now, I'm not interested in 24/7 recording and ideally I'd only want to be recording when motion is detected in the back garden
- Due to budget I'm not looking at using an NVR or dedicated PC for recording at this time. I have a Synology NAS that can run Surveillance Station but I'm looking for a camera that can record to micro SD to use as redundant recording (or instead of the Synology if I encounter issues due to the age of my Synology (a DS414j)). If the antisocial behaviour continues or the thefts in the area escalate to include break-in attempts (especially at front of houses) I'll look into an NVR or dedicated PC (as well as additional cameras) then (when I hopefully also have the budget to do so)
- Budget is a bit short at the moment so probably only about £200 to spend on camera(s) (I'm aware a PoE switch will be an extra expense I'm going to have on top of this)
- Given the lack of light cover on my sheds, unless someone has already been close enough to the house to trigger my light, I'm wondering if I'd be best served by a camera that has a built in light that would be triggered wherever motion is detected in the garden (depending on how bright any such lights get as to whether they'd be any use).
