Hi,
I would like to buy a single injector for a Dahua cam (5442 - IRE - not led).
This is the voltage and consumption specs:
I'm not sure about the required poe injector to buy.
It should be <7.2W, so 12v/1a will be good?
Should i consider the power (W = U x I) only while getting any combination of amper and voltage?
Thanks.
| Power Supply | DC 12V (±30%), PoE (802.3af) (Class 0) |
| Power Consumption | <7.2W |
Thanks.
