Hey guys, I'm going to run this by the experts (you) before I order so I can be sure I am ordering the proper equipment for my needs. Starting with 3 cameras, but like that this will be upgradable when I add more in the future. Thanks @milkisbad for info so far.
NVR - LTN8708-P8 and a hard drive
Camera 1 - CMIP3032 4mm dome Driveway (about 30 feet long and 20 feet wide). I made an educated guess about the 4mm based on some pictures I saw, any input here?
Camera 2 - CMIP3022W-28 front door. It'll be about 10-12 feet off the ground facing out from just above and to the side of the door.
Camera 3 - Side of house - still about 10-12 off the ground. Mainly watching a gate area that leads to back yard. Was thinking the same as camera 1 again, input appreciated.
Camera 4 - still up in the air. May use as a back door camera and stick with the CMIP3032
All will be PoE so I can run from closest internet access point in my house.
Thanks a ton guys.
Pete
Thanks a ton guys.
Pete
