looney2ns
See if you can find a reset button, maybe tiny, just big enough for a paper clip. With cam powered on, press the reset button for at least 30 seconds.I've tried to add the camera and tested all the Grain related profiles under IP Camera, I've tested adding ONVIF but it's not showing up. When I scan the network while adding the camera, the network activity light on the camera promptly reacts to the scan, but it's still not broadcasting anything that I can catch. No DHCP lease or anything.
I think I'm not getting access without a new firmware, so I think that's where I need to focus my efforts.
If that doesn't work, then power off the camera, press in the reset button, while still holding in the reset button, power camera back on, and continue holding button in for at least 30 second after applying power.
