Replacement for Hikvision DS-HD1?
JimLS
Feb 8, 2020
53
22
Illinois
Have had this for quite some time and the motion sensor cover is completely gone - just fell apart from sun exposure although it is shaded about half the year. I also felt it on a warm, sunny day (not particulary hot) and the body was VERY warm. Have read that others noted this also. I noticed it doesn't have any night vision - might be a setting change needed - I see two LEDs lit by the camera. Anyway, due to all this I am thinking seriously about replacement. Use zoneminder and don't use any of the motion detection. Just have doorbell wiring and way to much trouble to run network cable for POE. I see the Reocam is recommended but it doesn't work with existing chime. I suppose that isn't a show stopper as long as I have some sort of similar audible tones. Are there others I should be looking at? Don't want any cloud connections but can block them if they don't stop basic operation.
