C CamlessJ n3wb Feb 1, 2022 4 0 FL Nov 16, 2023 #1 Several of my lenses are sun damaged and the cameras wont work at night (IR illuminator illuminates the lens rather than outside). I have not found the correct size on Amazon nor Ali. Any links?
Starglow Getting comfortable Dec 13, 2018 410 697 North Carolina Nov 16, 2023 #2 Might be best to call them directly...my guess would be no replacement parts are available. but it never hurts to ask. About Us!
C CamlessJ n3wb Feb 1, 2022 4 0 FL Nov 16, 2023 #3 I did, they dont carry them anymore and dont have specs. I have measured the domes but have not found suitable replacements. 2.2" high; 3.75"ID and 4.25" diameter at flange
alastairstevenson Staff member Oct 28, 2014 16,231 7,007 Scotland Nov 16, 2023 #4 CamlessJ said: I have not found the correct size on Amazon nor Ali. Click to expand... It might be worth a look round here, a seller I used a while back, they have a good range and also provide some dimensional drawings. https://www.aliexpress.com/store/1776056 Reactions: TonyR and CamlessJ
C CamlessJ n3wb Feb 1, 2022 4 0 FL Aug 6, 2024 #5 Still chasing after these. Is there a corresponding Hikvision part number for Eclipse ECL-IPDM43V
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,326 48,134 Alabama Aug 9, 2024 #6 CamlessJ said: Still chasing after these. Is there a corresponding Hikvision part number for Eclipse ECL-IPDM43V Click to expand... If you're unable to find replacement domes, for $12 I'd try one of these headlight restoration kits. ==>> Ceramic Headlight Restoration kit Headlight Cleaner and Restorer kit-3 Easy Steps Restore Car Headlight Cleaner Cleans Yellow Haze Scratch Off-No Tools Required Sure, it's a slight gamble but I spent almost that much on myself at Chick-fil-A yesterday. As an Amazon Associate IPCamTalk earns from qualifying purchases. Reactions: mat200 and looney2ns
