Hello mates
I have to replace my actual 2332-I camera Hikvision cause of a bad isolation from my part.... (next time i will learn the lesson... :sad::sad: )
The question is:
I have the Hikvision DS-1273ZJ-130 so.. the only ones i see could be replace my burn model are:
- 2CD3345-I (4 MP) (but a aliexpress vendor told me.. I need to drill in the arm bracket, because the holes done are not the same as 2332-I model)
- 2C2342WD-I (4 MP)
- 2CD2335-I (3MP) (the replacement model of 2332-I) (in this i don´t need to drill in the bracket)
So, what are your opinion?
I also see the favourite vendor, CCTV CAMERA CHINA dissapeard... so, at this moment, what are the best and trusted stores to get one new with warranty?
Thanks in advanced
The question is:
- 2C2342WD-I (4 MP)
Thanks in advanced
